11-05-2024
09:47 AM
09:53 AM
James_C
I have a Canon EOS R10 and it seems that, when I take a picture, I accidentally touch the screen and change the Exposure Compensation.
Is there a way to lock it?
11-05-2024 10:26 AM
You could try adjusting settings here:
11-05-2024 10:26 AM
11-05-2024 07:28 PM
Thanks!
11-06-2024 04:42 AM
One easy way to temporarily deactivate the LCD screen is to use the LOCK button on the camera and configure the multi-function lock to also lock the touch screen. The manual page here shows the quick control dial, joystick and lens control ring being locked, you need to add a check mark in the fourth space to lock the touch screen.
https://cam.start.canon/en/C006/manual/html/UG-09_Set-up_0230.html
One benefit of this approach over completely disabling the touch screen is that if you press the Q/SET or MENU button on the camera you can then use the touchscreen as normal.
