EOS R1: flash burst speed lower when non-flash exposure is underexposed
karmlol
Enthusiast
Firstly, let me describe my issue: I have an R1 and a 600EX II RT flash. When I set everything to manual (shutter speed, aperture, ISO and flash power), it should take photos at the same burst speed regardless of what I'm shooting (some photos would just end up exposed differently). However I'm finding that when my subject would (without flash) be underexposed, the burst speed WITH flash is much lower, despite everything being identically set on manual.
Here's a video example: https://www.youtube.com/watch?v=cH8uXa50IGA
It starts out black (because of exposure simulation, the scene is underexposed without a flash), but as soon as I half-press the shutter, the scene brightens up. The burst that then follows is slower the darker the subject is, even though shutter speed and flash power are identical.
My suspicion is that it has to do with the scene preview exposure behaviour, where it automatically turns off exposure simulation whenever a flash is attached (or whenever metering starts with a flash attached): https://www.youtube.com/watch?v=ZjWVEQbdi40
I suspect it tries to properly expose the scene because there is a flash attached, increasing aperture to f/2.8 (up from f/5.6) and increasing ISO, and then has to swap back to f/5.6 and ISO 200 again for the photo. (And then back and forth again and again in between burst frames??) I cannot think of any other explanation why the burst rate is different with all those settings identical in full manual mode. Burst rate isn't bottlenecked when not using flash, so that rules out processing or card write speed issues.
Has anyone else come across this issue, and is there any possible workaround that does NOT involve taping off contacts and removing the possibility of using E-TTL?
I've read this thread on a related topic, however my use case is different because my flash burst rates are actually significantly reduced because of this issue, whenever relying on flash to fill an underexposed scene.
39 REPLIES 39
No it can’t the EF 100mm F/2.8L Macro IS USM is only capable of 12 fps. The aperture cannot stop down fast enough to achieve 20 fps. Even if the camera is set to H+ it will slow to match the lens’ speed.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
Do you think the lens’ aperture cannot stop down fast enough.
-Demetrius
“ The camera is set to one shot AF or manual focus, and the issue occurs on both of those settings. It's not AF related. “
I admit to not having watched the video.  It could be any number of things.  From lens IS to camera AF settings.
But the constant is the lens’ aperture motor. Older EF lenses don’t support the high fps. A lot of them max out at 12. But the OP is trying to shoot 20 fps. Which isn’t possible the camera will slow down.
-Demetrius
I didn't mean battery charging, I meant recharged. I'm not taking burst upon burst in hasty succession and blaming fps drops on that. You can see in my video, the fastest burst is the last one. (And there were no major soaking bursts right before the video.) The behavior is also fully consistent when repeated, regardless of the order. The only factor is the brightness of the subject.
I don't fully understand your claim, because I don't know why a lens would need to stop down "fast enough" during a burst at a consistent aperture (the aperture doesn't open and close, it stays the same). However let's assume that you're correct and the highest FPS in my video is 12 (it could be, I haven't exactly measured). Why then does the FPS drop FURTHER down to 6 fps ONLY when shooting an underexposed subject? With all settings on manual?
My question isn't "why don't I hit 20", my question is "why does burst rate slow down to 6 when taking photos of an underexposed subject, when the exact same manual settings give a MUCH higher burst rate on a well-lit subject".
The issue occurs even with IS disabled and manual focus (no AF).
With Canon the lens aperture stays wide open until the shutter button is fully pressed. In between shots it opens back up and then stops back down to the selected aperture. Regardless of what the aperture it’s set to. In burst mode it opens and closes. It NEVER stays closed during burst shooting. That would be stopped down metering. Canon’s EOS line had NEVER used stopped down metering. It’s always used full aperture metering. This is true even on DSLRs.
-Demetrius
Ok, that is interesting information. I will try doing a 40fps burst with that lens (without flash) to see if that is true.
However, my question (why the difference in burst rate between the different cases shown in the video) remains.
There’s no need to see if the lens will keep with a 40 fps burst. The camera will AUTOMATICALLY slow down to the lens’ max fps. I’ve tried on both DSLR and mirrorless. The lens’ aperture can only stop down so fast. I did a burst test with an old EF 70-210mm F/4 lens from the beginning of the EOS line. With my EOS 5D Mark IV with it set to burst mode and sure enough it slowed down the camera AUTOMATICALLY to the lens’ max FPS which is 3 FPS. I’ve even tried with newer EF lenses that support 12 FPS. The camera will ALWAYS match the max FPS that a lens can do.
-Demetrius
