06-14-2025
07:12 AM
08:32 AM
why am i not able to set the af setting in the first pink menu of canon r1?
06-14-2025 11:12 AM
What lens is on the camera? Normally if an EF or RF lens is fitted you can choose from the available options. It looks like a lens is attached since the line above only shows manual focus when no lens is attached.
06-16-2025 06:04 AM
Currently I have a Kit RF lens on R1. As I am setting up the new camera for use in the field
06-16-2025 05:53 PM
Can you set the AF area from the shooting screen by pressing the Q button?
06-16-2025 07:57 PM
If you press the SET button while the blank AF area bar is highlighted, do you get a message or warning?
Newton
06-16-2025 09:47 PM
Exactly which kit lens are you using?
