09-07-2021 09:49 AM
Hi All,
I've had my EOS R since the middle of May and am pretty familiar with all the controls. By default, I have the camera set to save both RAW and JPEG images. I normally don't shoot in fully Automatic but yesterday I found myself in unfamiliar territory with the shots I was going after and set the dial to A+ just to get a baseline to adjust from.
All of the images captured while in A+ were only saved in JPEG format. I made no ather adjustments to the settings and when I switched to a different Mode the camera again saved in RAW + JPEG. When I tried to duplicate the situation later, switching to full Auto - the camera saved it in the default way of RAW + JPEG. I've been through the manual and the forums and can't find this behavior mentioned. Any idea what might have caused it? Thanks.
09-07-2021 12:49 PM
Did you remove a memory card, and then replace it?
09-07-2021 02:17 PM
No, I switched from FV to A+. While shooting in Automatic it saved only JPEG. When I switched back to FV it saved both RAW and JPEG again
09-07-2021 07:07 PM
@billkard wrote:No, I switched from FV to A+. While shooting in Automatic it saved only JPEG. When I switched back to FV it saved both RAW and JPEG again
That sounds odd. But, it also sounds like it could be normal behavior for [A+] Automtic mode, too. Is it repeatable? If not, then I would look elsewhere for the cause. What else changed?
09-08-2021 09:58 AM
I often take pictures in A+ and they are always saved in RAW + JPEG. This is the first time it's happened. I turned the camera on later in the day, changing nothing as far as menu settings, swithced to A+ and the camera saved in both RAW + JPEG. I'm wondering if I touched something by mistake to cahnge how the pictures are saved - I just want to make sure I don't do it again. Or if it pops up I can change the settings back.
