EOS 5DS R Reducing size of RAW and JPEG images
hvulpus
I'm off in France photographing Romanesque churches with a 5DSR which renders wonderful detail.
I find that reworked RAW images, which seem to save as PSDs, can be huge, up to 130MB.  The RAWS are all in the 60MB range to start and the JPEGs in the 20MB range.
How does one reduce such large images to a manageable size, say, to send via email or use in Powerpoint?
Howard
14 REPLIES 14
Tronhard
VIP
VIP
Hi again:
I see a series of posts in this vein and your project sounds very interesting.
The question I would have is what post-production software are you using?   I use PS and have no issue in saving the final images as JPG files in a vastly file reduced size.  For example, I reduced an image of over 80GB to about 6GB - of course there is a reduction in resolution, but that is inevitable if that is the requirement.  The alternative is to link to a large file.
If you want to send images of large size, the best thing is to use a file-sharing program such as Google Drive, MS OneDrive, Box, Dropbox, or iCloud Drive.
cheers, TREVOR
March411
Good day hvulpus.
What image editing software are you using. I'm going to assume Photoshop since you said the images are saving as a PSD.
When saving an image in PS using the "Save As" command the default is PSD and jpeg is not in the selection drop down pane. You can easily fix this by going into preferences, once open go to file handling (red arrow). look in the main pane on the right and you will see "Enable Legacy Save As", check that box. Now when you use the "Save As" command the drop down will display several options for jpeg, the top jpeg selection is the standard.
Choose your directory, name the file and save. This dialogue box below will appear giving you have the ability to save it as a large or small file.  Use the slider or enter a number 1-12 and select OK. File is saved and the size you desire. If you don't want to change your preferences the to save as a jpeg just use the file "Save As Copy" prompt and follow the same process. For me old habit's die hard so I changed my preferences. I'm just used to going to "Save As" when working with files of any type.
Hope this helps.
Marc
Windy City
To find common ground you must be willing to search for it.
Our interests intersect more than they diverge.
R5 Mk II ~ R6 Mk III ~ R7
Lenses: RF Trinity and others
Personal Gallery
wq9nsc
For many years, my fast approach to reducing a file to smaller size for email etc. is to use the program IrfanView which is a very versatile program.  It can handle display of pretty much any format of image file and one of its features is you can specify a desired file size when saving a jpg file to make it any reduced size you want.
It is a free program but I make annual contributions to the author because I use it so much.  It has been my default jpg viewer on my PCs for well over a decade.  Just make sure that if you decide to download it, go to the official homepage and not some place that tries to bundle other stuff with the download.
IrfanView is what I use here when decreasing image files to stay within the posting size limit for this site.
Rodger
Waddizzle
I don’t think you can reduce the size of your RAW files without compressing them and potentially losing data.  But you can significantly reduce the size of JPG files by simply reducing the bit depth.
I don’t know how you plan to use the files.  Images displayed online typically have only 8 bits of color resolution.
I just download the application, I'm going to have to give this one a spin around the block.
Thanks!
Marc
Windy City
Personal Gallery
Roger,
Irfanview is my program of choice too.
Steve Thomas
Marc,
Be sure and take a look at the plug-ins which add a lot of versatility to the program.
Rodger
I have been using irfantview as a viewer for more than 20 years probably. It's one of the best freeware I have ever used.
Frank
Gear: Canon EOS R6 Mark I, Canon 5D Mark III, EF100-400 L II, EF70-200 f2.8 II, RF50 and few other lenses.
Flickr, Blog: Click Fanatic.
Ron888
Rising Star
Another vote for Irfanview. It's my go-to resizer for basic needs. Hit ctrl/r, select pixel dimensions or percentage resize.Easy as
If i want to fussy about image quality i'll use photoshop.First i'll resize the picture,then use the save for web function.(ctrl/shift/alt/s).A 'before and after' window will pop up.Play with the JPG quality slider on the right to get the result you want.It will show how many Mb the picture will be as you're doing this.
Hint: the highest setting doesnt always give the sharpest picture! I think it's due to different jpg compression settings working best with certain types of detail in pictures.
