EOS 5D Mark IV freezing up in self-timer mode
jehnashley
I am having a sudden issue using self-timer mode on my Canon EOS 5D Mark IV.
I was taking some family pictures & then was going to do a large group photo using self-timer.  I set it to 10 seconds, press down the shutter button to start the timer and then run into the photo before the timer ends.
I have done this process many times before!
Yesterday the shutter would not fire . . . at all! then the screen would freeze up completely.  I was not able to press the Q to access the screen or anything.  I was panicked and worried the camera is broke.  Through a quick google search I learned that it was due to being in self-timer mode.  I turned the camera off of self-timer and sure enough I was able to fire the shutter button again.
Why am I no longer able to use self-timer?
Thank you!
10 REPLIES 10
deebatman316
What lenses, batteries and other accessories are you using on your camera. If they're 3rd Party remove them and retest with Canon equipment.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF Trinity, EF 85mm F/1.8 USM
Retired Gear: EOS 40D, EF 50mm F/1.8 STM & EF 70-210mm F/4
I am using a sigma lens, but canon batteries.  I do not have a canon lens to use--but I have done this before (with the current equipment I have).
Has the camera been updated. I would also borrow a Canon EF lens. To rule out the Sigma lens potentially causing a problem now.
-Demetrius
The camera has not been updated.
I will try with a canon lens!
I just tried with my 50mm lens (canon brand) and the same thing happened! 😞
stevet1
jehnashley,
Is the 2-second timer also misbehaving?
Steve Thomas
Yes!  I get the same response for either timer.
I just took some pictures of my husband & kids for father's day!  Works perfectly fine.  Tried the self timers again and it froze up!  So weird.
jehnashley,
I'm not sure what to tell you. I don't see anything in the camera's menu system to tell you to Enable or Disable the self-timer.
Two things I might look at:
1) Have you tried a remote control accessory, and does the same thing happen?
2) If you are in One-Shot, the camera will not take a picture if it can't achieve focus. If you are in Servo mode, the camera will take a picture whether it's in focus or not.
Other than that, I can't think of anything.
Steve Thomas
I checked the focus.  It was in Servo so unfortunately that isn't the problem.  Thank you so much for your suggestions!!
I don't have a remote, but I will get one & try that
Avatar
