EOS 40D
Huntergks
I have a Canon A1 with several lens that I would like to use on my EOS 40D.  Does Canon or any other reputable company make an adapter?  If so, where can I purchase one.
Thank you,
George
3 ACCEPTED SOLUTIONS
Tronhard
VIP
VIP
Welcome to the forum:
I am not sure if anyone here is going that far back as far as lenses they use on a modern DSLR, but a 30sec search on Google found this:
FD to EF Conversions for Canon FDn Series Lenses
cheers, TREVOR
normadel
There are numerous adapters to mount FD lenses on EOS cameras. A reputable brand is Vello.
The problem is, without going into the technical explanation, is that in order to maintain infinity focus, the adapter has to have an optical element (lens) in it because of body lens flange - to - image plane distance differences. These are all low optical quality and have negative effects on image quality. They are pretty inexpensive, especially the no-names you can find on eBay. Some adapters have removable elements (my Vello does), but if you remove it....no infinity focus.I use mine with an FD-mount 500mm mirror lens. This allows infinity focus because mirror lenses actually focus PAST the infinity point by themselves, so the adapter still gives focus TO infinity.
Legend has it that Canon made a high-quality FD-to-EOS adapter at one time. I've never seen one in the flesh, or for sale anywhere. It was very expensive when new, and  it's said that it would be worth a huge amount of money if you did find one.
I hadn't heard of the mount conversions in the link given by Tronhard. These involve replacing the lens mount entirely, making the lens unusable on FD-mount cameras. And the one I looked at was $146.00. You have to be awfully desperate to use your FD lenses on your EOS camera to spend that. Possibly for a REALLY special lens. Not practical, to me.
You've reached the sensible conclusion.
One handy thing I forgot....If you like to do macro photography, an FD-to-EOS adapter, with optical element removed, does let you mount an EOS body on a macro bellows that has FD lens mounts.. I do this, too. This makes Canon bellows still valuable. You can make use of any FD (or older FL) lens on the front of the bellows, including Canon's fine  macro lenses. There are no EF-mount bellows, unfortunately
6 REPLIES 6
Tronhard
VIP
VIP
cheers, TREVOR
I'm not sure if my original response made it but Thanks, I'll check out that site.
George
normadel
Huntergks
WOW!!  Thx for all the great info.  Like you, I heard that canon mad an adapter years ago but I never could locate 1.
I have several A1 lenses but the 2 I wanted to use are a Sigma 600mm & a Spiratone 20mm.  I do have a Canon 100-3300mm & it does reach out pretty well.  It sounds like it would be easier, more practical, & more productive to just buy new lenses.
Thx again for all the info.  I appreciate it.
George
Huntergks
Thanks again.  I appreciate it.
