03-27-2019 03:35 PM
I have a problem where lights (taillights and even inside on car gauge dials, the light is not red but purple. Anyone have any idea what could be the problem? I am using 5d MkII with 17-40, white balance is automatic. I am shooting hundrets of cars and editing one by one is a big job. Thanks for your anwsers in advance.
03-28-2019 09:51 AM
Then why did the video not have the problem?
Most Red LED's do not have much ultraviolet, it is the white LED's that use phosphers.
03-28-2019 10:22 AM
@kvbarkley wrote:Then why did the video not have the problem?
________________________________________________________________________________________________
Ah ... good point, I hadn't looked at the video
03-28-2019 12:14 PM
Most Red LED's do not have much ultraviolet, it is the white LED's that use phosphors.
Maybe the video was taken with a UV filter?
03-28-2019 12:29 PM
No, withouth any filter. It is not the same car, 3 years older. Also LED-s. Since the problem is with the new cars, it could be different LED-s, stronger or something.
03-29-2019 02:50 AM
@VektorCRO wrote:No, withouth any filter. It is not the same car, 3 years older. Also LED-s. Since the problem is with the new cars, it could be different LED-s, stronger or something.
You need a CPL filter.
If you have a CPL filter, then try this short experiment. Hold one up, and look at your LED TV screen, or computer monitor. Now begin to slowly turn the filter ring until you have turned it in a complete circle. Viola! Your problem can be solved.
03-29-2019 06:30 AM
This works with LED TV screens or computer monitor screens because they have an inbuilt polarizing filter, sadly it does not work with direct LED lighting.
03-30-2019 03:26 AM
@Ray-uk wrote:
@Waddizzle wrote:
If you have a CPL filter, then try this short experiment. Hold one up, and look at your LED TV screen, or computer monitor. Now begin to slowly turn the filter ring until you have turned it in a complete circle. Viola! Your problem can be solved.This works with LED TV screens or computer monitor screens because they have an inbuilt polarizing filter, sadly it does not work with direct LED lighting.
You are probably correct. I thought solid state light sources produced light that was already polarized. Don’t they add filters to TV monitors to “sharpen” the image coming from the emitters?
I understand what you are saying, but I do not see how a CPL would not be a good solution for cutting the glare and intense iight from solid state light sources.
03-28-2019 10:33 AM
03-31-2019 04:15 PM
Hers is another example.Left light is purple and right red. Flash is bounced of the celing....
03-31-2019 08:35 PM
@VektorCRO wrote:Hers is another example.Left light is purple and right red. Flash is bounced of the celing....
Are the car's lights even turned on?
