07-24-2023 06:20 PM
Hello!
I recently inherited a Canon T50 and have been experimenting with film photography. However, whenever I attempt to shoot, the P warning for dim lighting flashes, regardless of how dim the lighting actually is. I could point the camera directly at the sun and still the P would flash. Is there any way to fix this? Or, if the problem is not fixable, could I use the manual aperture settings to circumvent it?
07-24-2023 07:02 PM
These types of situations are often hard to solve. Typically, because of parts availability. I think a complete camera replacement would be the most economical option, but you never know.
If you are looking for a good repair shop, try midwestcamerarepair dot com.
07-24-2023 09:25 PM
Is the light meter battery good?
07-24-2023 11:36 PM
🤔 I think the T50 only uses 2 AA batteries. I don't believe it has a Light Meter Battery.
Canon T50 User's Manual (35mm-compact.com)
