03-05-2014 05:37 PM
03-09-2014 09:05 AM
Hi henrychan!
Thanks for posting.
To disable the flash from firing, simply turn the mode dial clockwise one more setting to the Flash Off mode. It is the same as Auto, but the flash will not fire.
This didn't answer your question? Find more help at Contact Us.
03-13-2014 02:06 PM
Thanks for answer. I can disable the flash for 1 shot with no problem. My question is how to disable flash for MULTIPLE shots.
Henry
03-14-2014 05:33 PM
Hello henrychan,
The best mode to use, versus flash off or Creative Auto would be Program mode. The flash will not pop up unless you physically activate it. That advantage, along with the ability to set Continuous Shooting mode, would make this ideal for your shooting needs.
If you require further technical support or other questions, we would be happy to assist you. You can get in touch with technical support direct through our Contact Us web site.
