02-20-2022
11:45 AM
08:48 AM
Anybody else having this problem with the Canon R6 freezing up. It usually starts with the camera not focusing. Its also becomes none responsive to mode changes. The on/off button doesnt work. Opening the battery door shuts it off... but still doesn't fix it. Pulling the battery out usually fixs the problem right away. But again... not always and sometimes it take a few battery removals to get it back up and running.
This has happened while shooting both photo and video. It happens with different lenses. It happens with different memory cards. I can't recreate the problem on command. The camera works 99% of the time. But at least once a wedding shoot, over the period of 6 hours, It freezes up!
In the video below... I was attached to the Ronin gimbal. But it's happened just shooting photos and without the gimbal. Plus, when I open the battery door and try and turn the camera on/off... it still doesn't work. Has nothing to do with that.
I was on firmware version 1.4
I updated the firmware this week to version 1.5.0.
This problem has been happening for a long time... 8 months. Camera is less than a year old.
Again, at last nights wedding... it froze.
Here is a video that I recorded when it happened.
1. Focus isn't working. Both back button and touch.
2. Display freezes up. You can still see the audio working.
3. On/off doesn't work.
4. open battery door... nothing works.
5. Pull Battery
12-06-2023 03:16 PM
I have had the same problem! I sent it to Canon for repairs. They said the issue was the main board and they replaced it, BUT, I was photographing an event the other night and the problem started again...happening more often. I turn the camera off and wait for the stuck shutter to close before turning the camera back on. I am getting very frustrated, as this is an expensive camera!
12-06-2023 03:17 PM
Again, same problem. I have the latest firmware and canon replaced my main board.
12-06-2023 11:07 PM
They replaced my whole camera and the problem is still there. Canon just announced their latest version 1.8.3 let us see if that solves the problem. I shall download and install today.
12-07-2023 05:24 PM
Canon received my camera today to repair the repair. Fingers crossed.
12-07-2023 05:28 PM
I am in the same situation. I do a lot of nightlife photography, and I literally don't have the option to send off my camera, as it will be to long b4 I get it back, especially with Nye round the corner.
12-07-2023 05:37 PM
I have a CPS membership and it has certainly paid for itself this year!
12-08-2023 05:40 AM
It would be best if this old thread were locked. More and more “me too” members are adding to this thread with their own set of unique issues causing similar symptoms. I have used the R6 mark II for nearly a year and have not experienced any lockup issues.
Here is a checklist of items members should verify if they are experiencing issues. This advice is a best practice for any camera body, no matter the brand or manufacturer.
I doubt if this is a complete list of things to check. Only a Canon specialist is able to do that.
12-08-2023 06:47 AM
I am not using any 3rd party hardware.
I am not using cheap &/ slow SD Cards. I use SANDisk.
I have always used the latest firmware. Each time hoping that the problem is gone. But was disappointed to see the camera freeze again.
I have had the camera replaced and also a reset was done in between.
Now I have downloaded the new firmware 1.8.2 and will try with this.
12-08-2023 01:29 PM
@DhandaNot wrote:I am not using any 3rd party hardware.
I have had the camera replaced and also a reset was done in between.Now I have downloaded the new firmware 1.8.2 and will try with this.
The devil is in the details. Assume nothing.
Your response does not address Wireless Communications. This is the most likely cause of cameras locking up as it tries to establish a wireless connection with another device.
Memory cards are notorious for causing cameras to lockup. There are counterfeit cards for sale all over the Internet, most especially at online marketplaces like Amazon.
12-09-2023 04:32 AM
Sorry forgot to mention that WiFi or Bluetooth neither is on. I have the Airplane mode on.
Now about the SD Cards, yes they were purchased from Amazon.com. I have no way to prove that they are genuine, but I do believe they are. If they were not, I would have seen a lot more issues all the time and not just Camera Freeze that is seen once in a while.
It has uncanny habit of doing that exactly when the bird is about to fly or the Cheetah cub is about to jump kind of situations.
My fingers are crossed for the firmware 1.8.2
