04-21-2022 11:42 PM
So I've used external intervalometers for years with my T series and 70D bodies but having an issue with the R5. The external intervalometer works the same as previous ones but just with a different end. I can set up a run fine, like 4 second shots with a 5 second interval and the external intervalometer seems happy with everything and goes about it's program when I click Start.
The problem is the first exposure opens the shutter but after the 4 seconds isn't ending the exposure and closing the shutter. The intervalometer goes along it's program unaware the camera never ended that first shot.
Best I'm finding on forums and such in searches is that MAYBE I have a bad (brand new) intervalometer. Suppose that could be it but wanted to ask if anyone else has run into this behavior before. TIA!
04-22-2022 02:04 PM
Yep, that's how most intervalometers work. And the 4 seconds was just an indoor lighted test. It doesn't matter what I chose - last night was 30 second shots and normally with a wired external intervalometer you set a 31 second interval and it works like you said. I tried 4 second shots with a 5 second interval, 30 second shots with a 31 second... nothing stopped the first exposure.
So I resorted to using the built in one and doing 30 second shots with a 34 second interval but that's not really ideal. Unfortunately if you don't give the R5 a longer gap after the shot it won't time everything right apparently so 30 second shots with 31 second intervals on the built in doesn't work. Which the same has been reported all over online - no idea why the camera can't take that next shot reliably a second later.
04-22-2022 02:54 PM
Well, I've went ahead and purchased another and a different brand. Once it arrives I'll update this post if it was just a faulty intervalometer and nothing more.
04-26-2022 09:08 AM
Just wanted to update this post that the first intervalometer must have either been faulty or isn't compatible with the R5 like it says it is on Amazon.
However, this intervalometer worked exactly as it should for me:
https://www.amazon.com/gp/product/B01MR86TMN/
05-19-2022 12:31 PM
The R5 intervalometer can shoot at 1 sec intervals. Be sure you are using the most current firmware.
05-19-2022 01:29 PM
Yeah, it seems like they have apparently fixed it. Was an issue when I first got the R5 and I'd read a ton of posts saying the same thing but I just ran a test with 10 second manual exposures with an 11 second interval and it didn't get off-count at all. Nice to see that's a viable option now!
