10-06-2022 11:25 AM
10-10-2022 01:27 PM
After viewing your video, I tried the same thing on my R5 and can confirm it behaves as you indicate. It looks like something Canon needs to look at in a firmware update.
10-10-2022 01:41 PM
Thanks Trevor, at least someone understands that this should probably NOT be normal behaviour. I find it quite interesting that everyone offers lots or workarounds and excuses for this. I personally find it a really frustrating quirk on Canon bodies. If you actually wanted to configure/use a longer meter timer you basically cannot get back into AUTO ISO mode without using the Q button or another menu combo.
10-10-2022 01:44 PM
You keep referring to Canon BODIES (plural) - have you experienced this with other Canon models?
10-10-2022 01:50 PM
Observed on both the R5 and R6
10-10-2022 01:53 PM
OK, I will check my R6 units and see if this is the case for me. If so, the issue seems to be limited to the MILC systems, but it is an issue and should be addressed.
