10-06-2022 11:25 AM
10-10-2022 10:17 AM
You can change ISO mode from AUTO to manual by opening the Quick Menu.
10-10-2022 10:36 AM
Not if your camera is in an under water housing 🙂 Anyway I appreciate there are workarounds. I just wanted to understand if this was standard method of operation on Canon's range of mirrorless bodies. Which I guess it is from your previous responses.
10-10-2022 12:57 PM
I'm not sure what specifically you mean by 'when the meter is active'. I have many Canon camera models and if I have metered a subject, I can select to go to and from auto ISO interactively. To confirm my opinion, I tested 3 cameras, looking through both the viewfinder and using the LCD at the back, and had no issue.
10-10-2022 12:59 PM
Can you access this video link on Facebook ?
https://www.facebook.com/100063683860930/videos/5925896504110735
10-10-2022 12:59 PM
10-10-2022 01:00 PM
No, I cannot. I get the standard FB message that the post is not available because the owner shared it with a small group, or the video is not available right now. I suggest a repost of the video on FB.
10-10-2022 01:12 PM
10-10-2022 01:24 PM
All brands work the same way. Did you know that One Shot AF locks both focus and exposure?
10-10-2022 01:27 PM
After viewing your video, I tried the same thing on my R5 and can confirm it behaves as you indicate. It looks like something Canon needs to look at in a firmware update.
10-10-2022 01:31 PM
Yes, I agree on that point. However, in most cases people use the back button for focus and de-couple this behaviour. I guess the issue is because the the meter remains active for a configurable timer and on some other cameras the meter timer must be slaved to the shutter button. I only experience this issue with Canon so must be specific to the vendor.
