Canon Macro EF-S 60mm 1:2.8 lens
yidianm
I bought a Canon Macro EF-S 60mm 1:2.8 lens for my T5i camera,
when I focus a object, no matter in MF or AF, it is clear in the window, when I take it, the picture is blur,
I took too many times and make sure my hands are stable, but still doesn't work, how can I do it?
thanks,
Mark
8 REPLIES 8
kvbarkley
Can you post an example?
Does the focus confirmation light come on and beep?
What other lenses do you have and do they work?
Mine has worked fine on 3 or 4 bodies by now.
ebiggs1
"Can you post an example?"
Please!
EOS 1DX and many lenses.
There is sound from lens druing focusing and the smal window changed to green and a beep from the camera when it is focusing. When I press button to take picture, the picture is not as clear as it shows in the camera window. But occasionally, I get a clear picture, maybe 10% chance.blue imagesIMG_3503.JPG
Please see images.
You need to use a tripod for macro photography.
I don't know if you need a tripod but he is correct in assuming you need to hold the camera still.  Your examples show camera motion.  In short you were not steady when you pressed the shutter button.
This condition is from not enough light resulting in a slow SS.  You need to fix the light problem so you can boost the SS.  Try a higher ISO, see if that helps.  If not additional artificial light will need to be supplied by you.
You need a tripod, and you need to use Av mode.  A remote shutter control, or the shutter delay timer, would help, too.
Yeah - that's motion-blur.  When hand-holding that particular lens, you probably want a minimum shutter speed of 1/100th sec. Or just use a tripod (or rest the camera on something so it doesn't move.)
Tim Campbell
5D III, 5D IV, 60Da
