Canon M50 Water Splashed
minimalized
Hello fellow Canoneers,
Yesterday, my beloved M50 got splashed by a very small amount of water. Everything works fine, except the mode dial only switches between Av, Tv and P modes. Is there a way for removing any moisture from the dial? Is disassembly required?
11 REPLIES 11
After following, what you said (heating pad and all) the camera came back to normal function. I can't thank you enough. I laid it on the heating pad, upside down so that the affected dial fully touched the pad and it worked wonders! Thanks again for the amazing advice!
ebiggs1
EOS 1DX and many lenses.
