04-12-2023
04:14 PM
04:22 PM
I have made a firmware update from 1.5 to 1.8 ect now i have an err 70 when i download the photos in dpp , am i de only one Who have this ?
04-14-2023 08:41 PM
Hi Gerjanbo,
I'm sorry to hear you are seeing Err70 on your EOS R5. That error is shown when the camera is unable to write files to or read files from the memory cards. For that error we would recommend loading different memory cards in the camera, take some test images, and check to see if the same thing happens.
If this is only happening with one specific memory card that would indicate it is the cause. In that case we would recommend contacting the maker of the memory card to trouble shoot it. If the error happens with every memory card you load in the camera at that point we would recommend sending the camera in for repair.
The Canon U.S.A., Inc. online repair portal allows you to set up service in a few simple steps. The repair portal gives you the ability to set up service for multiple pieces of equipment at once, and to receive a repair estimate in the majority of cases, depending on your model and issue. The portal also allows you to upload images or videos that will assist us in repairing your product. You can also select how you wish to be notified of the progress of your repair. The portal's service history section allows you to view all services that have been performed on any of your camera or video products since January 7, 2020.
Please follow the link below to access our online repair portal to arrange for service:
https://mycanon.usa.canon.com/signin
Instructions for Accessing and Using the Online Repair Portal
You will need to access or create your My Canon Account.
If you already have a My Canon Account and your product is already registered, simply click on the “Get Repair Services” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you have a My Canon Account and your product is not registered, you must register your product first. Click on the “Get Repair Services” link on the left menu, then click on the “Register Product” link on the right. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you do not have a My Canon Account, you will need to create one. After you create your account, click on the “Add Product” link to register your first product. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
Once you have completed the repair request, you will have an opportunity to print a copy of the request for your records. This request form will also contain shipping instructions and an address label that you will attach to the outside of your shipping box when mailing your equipment for repair.
04-14-2023 10:05 PM
The latest firmware for the R5 is v1.8.1
Please ensure this is the firmware you downloaded and installed.
Canon Support for EOS R5 | Canon U.S.A., Inc.
Once verified, please format your media in camera.
Now reset the camera's main and custom settings and retest.
If the error persists, try another card as Hazel_T recommends. Your card should be full size, not micro or adapted if SD.
07-31-2023 01:55 PM
Same issue here. It's not a card issue.. I've been using the same cards since I've had the R5 with no issues and now I get Error 70 all the time after updating to 1.8.1. I've changed out to other cards and the same thing is happening. FYI does not happen with the R6.
