06-25-2023 06:44 PM
Ive tried everything possible to prevent this from happening. Im using my m50 to stream on Stream Labs. After 30 min it goes to a black screen, and I have to click the shutter button to turn it back on. Not fun to do at all 🙂 I have it connected via usb to HDMI into an El Gato Cam Link 4k. Power adapter plugged in. I have all the stand by settings off. Ive watched ton of youtube videos and cant seem to find an answer if its possible to make this happen. The quality is awesome but I really want to avoid having to shutter 5-6 times when streaming. Thanks for any help!
06-26-2023 01:34 AM
All power saving features are off as well. And I’ve tried to use the EOS utility app but it never recognizes my camera. I tried using the EOS utility 3 and no matter what I do it won’t ever show my camera as connected 😞
06-26-2023 05:15 AM
The M50 does not have “Clean HDMI” output, which was added to the Mark II version of the camera. The shutting off is normal operation. The Webcam Utility uses the USB port. Do not make multiple connections to the HDMI and USB ports at the same time.
I suggest that you reset the camera settings back to their factory defaults. Do not try to adjust or change the power settings. Leave them at their factory default values. Carefully follow the installation and setup instructions at this link.
https://www.usa.canon.com/cameras/eos-webcam-utility
The regular EOS Utility must be closed. The EOS Utility Launcher Service must be disabled.
06-26-2023 12:13 PM
So should I be using the mini HDMI out on it to HDMI or the micro HDMI to HDMI? I’m using the micro and it pulls up on my pc but won’t show up under the EOS utility app
10-10-2023 01:32 PM
I have the same issue. When the display turns off the HDMI feed turns off with it. The culprit is “power saving -> display off”.They give us no option to disable that behavior entirely 😞. The longest you can set it is 30min.
I really wish Canon would release a new firmware for MK1 owners like us that would bypass this.
