06-25-2023 06:44 PM
Ive tried everything possible to prevent this from happening. Im using my m50 to stream on Stream Labs. After 30 min it goes to a black screen, and I have to click the shutter button to turn it back on. Not fun to do at all 🙂 I have it connected via usb to HDMI into an El Gato Cam Link 4k. Power adapter plugged in. I have all the stand by settings off. Ive watched ton of youtube videos and cant seem to find an answer if its possible to make this happen. The quality is awesome but I really want to avoid having to shutter 5-6 times when streaming. Thanks for any help!
06-25-2023 07:54 PM
Are you using the record button to live stream? If so, there is a 30-minute limitation in the camera for recording. I think you can live stream just using live view without recording. This may make a difference.
06-25-2023 08:16 PM
I have the setting on top of the camera on the little camera icon. Is the live view a different setting?
06-25-2023 08:23 PM - edited 06-25-2023 08:32 PM
I don't have that camera to confirm. I was asking if you are in the video record mode for your live streaming. If so, you are limited to 30 minutes of recording. If you can get video out on the HDMI cable without recording, I don't think that you will encounter the 30-minute limitation.
06-25-2023 08:34 PM
its not recording its live streaming just basically using the canon as a webcam so to speak.
06-25-2023 08:36 PM
So you aren't using movie record on the camera during live streaming.
06-25-2023 09:00 PM - edited 06-25-2023 09:02 PM
Canon has a Webcam Utility that uses the camera's USB connector to output video to your computer's USB port. If all else fails, you could try using Canon's Webcam Utility and USB cable without the Cam Link adaptor. There should be no 30 minute video limit using this method.
https://www.usa.canon.com/cameras/eos-webcam-utility#model
06-25-2023 09:07 PM
no but im a bit confused. should I be?
06-25-2023 09:11 PM - edited 06-25-2023 11:01 PM
If recording video, there is a 30-minute recording time, so no, you shouldn't use that mode.
06-26-2023 12:09 AM
One other thought, do you have any power saving features enabled in the camera?
