02-17-2018 07:30 AM
02-17-2018 09:34 AM
What lens are you using when you're not using the fisheye?
02-17-2018 09:38 AM
What is the lens model number? It sounds like the AF motors in the lens are jammed. Most of those screw on wide angle lens adapters are a waste of money. The image quality is bad, and they confuse the camera. They are usually included in camera kits by vendors.
As for your problem, I suggest that you buy a new lens. I suspect that you have the camera kit lens, which is one of the EF-S 18-55mm f/3.5-5.6 IS II models. It would cost more to repair, than to buy a new lens. The best replacement is the EF-S 18-55mm STM version of the lens.
Other good lenses to buy are the “pancake” lenses, the EF 40mm f/2.8 STM, or the EF-S 24mm f/2.8 STM. A lens with a slightly longer focal length is the EF 50mm f/1.8 STM, which would be great for portraits. Notice how all of the model numbers end with STM.
02-17-2018 12:05 PM
One thing to try: look at the lens and see if the lens looks crooked (someone might have knocked it out of alignment when removing the screwon lens). if so, try pusing in the opposite direction to see if it snaps back.
02-17-2018 06:12 PM
@jrhoffman75 wrote:One thing to try: look at the lens and see if the lens looks crooked (someone might have knocked it out of alignment when removing the screwon lens). if so, try pusing in the opposite direction to see if it snaps back.
Make sure the AF/MF switch is MF if you try this.
