06-11-2026
05:14 PM
10:07 PM
Tiffany
06-13-2026 05:22 PM
Oh, my! That is so helpful. I really appreciate you taking the time to send me all that info. I have followed all the info you gave me, and have found that screen comes up between taking pictures. I have now taken 17 pics outdoors, and am amazed that I am once again able to do this! I moved back to my little green mark on the dial, which is the "auto" mode, and the same pop up flash thing happened. I can only assume that there is a problem with that setting. So I am now able to take pictures, and thank you so much. Now to see how things work on my extreme lenses, which I use for bird watching, (why I got the camera in the first place!) . I have a chair mounted on an old jeep, and have finally been able to climb up to it! Wish me luck and thank you once again! Hopefully you'll not be hearing from me again!
Sincerely
Jenni
06-13-2026 05:23 PM
Thanks, yes, I have downloaded the manual, and (above) Steve is right....so much easier than the book!
I appreciate your help.
Jenni
06-13-2026 09:56 PM - edited 06-13-2026 10:01 PM
Jenni,
I'm glad I could help.
Yes. That info screen will come up in between taking pictures. That is normal behavior and to be expected.
With the flash popping up while you are in Auto Mode, that may be just a fluke of that Mode. Now that you are using semi-auto modes like Av, hopefully you won't have to return to Auto all that much.
With shooting birds a lot, you may find it useful to try TV Mode, where you set the shutter speed and the camera sets your aperture.
Shooting birds, you may find you are using speeds as high as 1/1000 or 1/2000 to freeze the action. As you go higher in shutter speed, the aperture will get wider to compensate and let in more light to give you a good exposure. If it gets too wide, that's where your Auto ISO will help give you a little boost. As your aperture gets wider, your depth of field will get smaller, but in your case, that's okay, because you will be kind of isolating that bird to begin with.
Servo will help you as well. Just keep that focus button pressed down and follow the bird along. The camera will keep him, or her, in focus.
I envy your ability to climb up on a chair to get up on your jeep. You're still going strong.
Share some of your pictures as you go along.
Steve Thomas
06-18-2026 09:08 PM
Thanks so much! I appreciate all your help and also all the others who answered. I think it is all ok now, and I am off this weekend to try it all out!
Many, many thanks.
Jenni
