Canon EOS Rebel T6 will not reset to factory
Jennim
Jenni,
I'm glad I could help.
Yes. That info screen will come up in between taking pictures. That is normal behavior and to be expected.
With the flash popping up while you are in Auto Mode, that may be just a fluke of that Mode. Now that you are using semi-auto modes like Av, hopefully you won't have to return to Auto all that much.
With shooting birds a lot, you may find it useful to try TV Mode, where you set the shutter speed and the camera sets your aperture.
Shooting birds, you may find you are using speeds as high as 1/1000 or 1/2000 to freeze the action. As you go higher in shutter speed, the aperture will get wider to compensate and let in more  light to give you a good exposure. If it gets too wide, that's where your Auto ISO will help give you a little boost. As your aperture gets wider, your depth of field will get smaller, but in your case, that's okay, because you will be kind of isolating that bird to begin with.
Servo will help you as well. Just keep that focus button pressed down and follow the bird along. The camera will keep him, or her, in focus.
I envy your ability to climb up on a chair to get up on your jeep. You're still going strong.
Share some of your pictures as you go along.
Steve Thomas
23 REPLIES 23
Jennim
For some reason my post did not show up, so I have replied to myself, LOL! . I have a Canon EOS Rebel T6 that will not reset to factory. I have tried all suggestions online from Google, Canon, youtube etc, including the instructions for "hard reset", and have had no luck.When I turn on the camera, I get a screen that shows me I have auto selected. After that I cannot go anywhere except to the menu. Pressing the button to take a pic pops up the flash but doesn't take a picture. The flash goes off, but no pic. No pic on the screen unless I hit the "disp" button,  and cannot make the camera view appear onscreen any other way.  The camera was turned off and unused for almost a year. It is kept in a moisture free wheeled camera carry-on style case, with all the attachments and lenses. I'm 81 years old and this has me quite confused, LOL!  Thanks for any help.
Jenni
Hoping that you don't store the camera with the battery installed.
Do you have another battery you can test with?
One of known good quality.
OMG, Rick! That is exactly what I did, because I didn't realise the camera would be out of action so long. (broken hip, wheelchair, blah, blah....) It appeared to charge ok when I put it on charge this morning, went from yellow to green in about an hour. I'll have a new battery sent in case that was the problem. No spare, sadly. Thanks for your input.
Jenni
Jenni,
Rick's suggestion of trying a fully charged fresh battery is a good one.
Usually, the flash will pop up if the camera senses a picture that is so dark that a flash is needed. Have you tried to take a picture outside on a nice sunny day?
Your comment about the "camera view" makes me wonder if you are trying to use "Live View".
Steve Thomas
The battery is suspect at this point.  I'd also take a look at the battery compartment with a flashlight.  You'll want to look for corrosion.  Hopefully none is present.  Charge the new battery fully before testing.  Hopefully that'll be it.
Please post a follow-up and let us know what you find.
stevet1
Jenni,
If you haven't done so yet, I'd strongly encourage you to download a copy of your camera manual.
You can find a copy here:
https://www.usa.canon.com/support/p/eos-rebel-t6#idReference%3Dmanuals
It's about halfway down the page. It will be in pdf format, but using a pdf reader like Adobe Acrobat, you can search for answers to specific questions. It will also explain what all the buttons are and what they are used for.
Steve Thomas
Steve, thanks for the reply....yes, I have tried the camera outside, it does the same thing. I don't think I have live view, but will check, thanks.
Jenni
I've looked in the battery compartment, and it looks squeaky clean. Will be ordering a battery today....I live overseas, in Belize, so it will take time to get here.... we have no camera stores here...😟 Thanks
Jenni
Hi Steve, my manual is looking very rumpled! I used it a lot, so don't need to download it. But thanks for the thought!
Jenni
