12-23-2018 10:16 PM
12-23-2018 10:42 PM
12-23-2018 10:45 PM
12-24-2018 06:10 AM - edited 12-24-2018 11:03 AM
My guess is that the adapter somehow bent the CF card pins at the bottom of the slot. Get a flashlight and magnifying glass and check them out.
If one is bent you might try straightening it out. You can do a Google search online for tips on how to straighten it.
12-24-2018 08:57 AM - edited 12-24-2018 08:57 AM
I agree with Mike's assessment that one or more pins were likely bent in the CF connector. I have never used a 5D M2 but I believe this one only has a single memory card slot which limits your options. If you are technically proficient you can try to straighten any bent pins. Use a good magnifier and excellent light making sure that parallax error isn't causing you to make an incorrect bend while attempting this repair. These pins should have been somewhat hardened during manufacture which means every bend will make them more fragile so don't overdo it during your repair forcing further bending and likely resultant breakage of a pin.
I would have on hand a very good quality large capacity CF card and plan on basically marrying it to the camera and transferring files with the card still in the camera once you get it working. I am not a fan of the CF pin interface because it is not mechanically robust and is fairly easy to damage. I use an ethernet cable for image transfer with my 1DX and 1DX 2 bodies rather than subjecting the CF and Cfast connectors to risk. The SD card connector is far more mechanically robust and I am glad my Canon XF-400 uses this reliable setup and this was the primary card I used with my older 1D Mark II which had CF and SD slots.
Your other option is to send the camera to a shop that still works on these and have them replace the connector; if you plan to continue removing and inserting cards this is your only real option because once a pin has been bent it will never be as strong asit was originally If you are very comfortable with precision repair, you could switch this connector from a parts unit. I have done repair and calibration of precision test gear much more expensive and complex than Canon camera bodies and I am comfortable with these types of repairs but it really isn't something that you should undertake unless you are used to working precisely with very small electronic components.
Good luck in getting this resolved.
Rodger
12-24-2018 01:20 PM
@wq9nsc wrote:I agree with Mike's assessment that one or more pins were likely bent in the CF connector. I have never used a 5D M2 but I believe this one only has a single memory card slot which limits your options. If you are technically proficient you can try to straighten any bent pins. Use a good magnifier and excellent light making sure that parallax error isn't causing you to make an incorrect bend while attempting this repair. These pins should have been somewhat hardened during manufacture which means every bend will make them more fragile so don't overdo it during your repair forcing further bending and likely resultant breakage of a pin.
Rodger
I once fixed a CF slot on a 20D for a colleague at work. (His wife had bent some pins by forcing a card in backwards.) It took a couple of hours, but wasn't especially difficult. The biggest problem is that you really need three hands: one to hold the camera steady, one to manipulate the longnose pliers, and one to hold the flashlight. Since it's really too cumbersome for a second person to intervene, it's a juggling act. But I did manage to get it working. (IIRC, I mainly held the flashlight in my mouth.)
12-24-2018 04:45 PM - edited 12-24-2018 04:46 PM
Bob,
You need one of those ultra-cool headbands with LED lights sticking out of them 🙂
I have really good lighting for my work bench with a couple of very adjustable lamps to get light where I need it but even with these little guys I know what you mean about getting the light exactly where you need it without casting shadows. I have repaired a few vintage meter movements and you need good lighting and 3 or 4 hands would come in handy at times.
Good job on successfully repairing the tiny connector!
After doing some restorations involving tiny modern components, my next project is a full restoration of this rare Hallicrafters receiver from 1938. At 30" wide and 20" deep one can just about crawl inside to work on it instead of trying to work under a microscope 🙂 This is a good thing because this one will require a lot to bring it back to factory condition but since it cost as much as a new car during the Great Depression few were sold and very few remain in existence.
Working on large electronics is a good practice method before delving into tiny modern stuff!
Rodger
12-24-2018 08:20 PM
@wq9nsc wrote:Bob,
You need one of those ultra-cool headbands with LED lights sticking out of them 🙂 ...
You know, I think you're right. I didn't have one of those at the time; but I do now, and it works pretty well.
At home I have an adjustable lamp that clips onto a table, and that might have made the job easier. But I was at work, where conditions weren't as good.
12-24-2018 09:17 PM
@RobertTheFat wrote:
@wq9nsc wrote:Bob,
I have a fluorescent one with the magnifying glass in the center, which I can no longer use. Had to give up repairs over a decade ago when my vision began failing due to my age.
12-25-2018 12:31 AM
