Canon A1 tune up price?
dknapp1117
My son is wondering about how to shoot pics on film.  I am the original owner of a Canon A1 that I loved back in the day. I haven’t used it for 20 odd years and I think the shutter is sticky. What price would I expect for a general tune up and cleaning for just the body? Where’s a good place to send it out to?
Thank you
Would be hard to guess about something like this.  Primarily because you might have difficulty finding someone who is capable or willing to work on a camera this old.
Try garrys cameras in illinois.  Shows a flat fee of $78.  Note: I have no experience with this company
11 REPLIES 11
Thank you, I will give them a try. Pro Photo in Washington DC was also suggested, but I haven’t heard from them yet.
normadel
What leads you to think the shutter is slow? It is electronically controlled. Slowness is not very likely.
I think you might be confused about what an Canon A-1 is.
Canon A-1 - Wikipedia
Just listening by ear, there’s a significant pause between hearing the shutter open and hearing it close. Could be a bad battery though. I will check.
It’s definitely the A-1. It also has a sticker showing 1988 from an earlier repair visit on the inside. A 36 year old camera could still need a tune up. The shutter itself is mechanical, only the timer is electronic. Could be a bad battery though, I will check that before sending it to anyone.
My post wasn’t to you. I don’t doubt you know what your camera is.
The A1 has a red light next to the shutter.  If it doesn't blink several times per second, the battery is low.  If it is blinking several times per second, then you have a different problem with the shutter.
Curious - what is everything set at on the camera?  Are you in bulb mode?
Gary
Lake Michigan Area MI
Digital Cameras: Canon EOS R6 Mk ll, EOS R8, EOS RP, ...and a few other brands
Film Cameras: Mostly Pentax, Kodak, and Zenit... and still heavily used
The battery is so low, I get no blinking lights. Measured by VOM outside the camera the voltage is about 0.2 v, instead of the 6v it should be. The camera is set to 1/500, F8, ASA 400, not B but good guess. My by-ear timing was a while ago, but without a good battery all bets are off. Thanks for the suggestions.
