12-16-2018 06:32 PM
I have a Canon 5D mark one with a low shutter count but in the cold all shots are black. When first out in the cold it takes a few shots then once it cools down that's when the issue shows up. Seems fine when used inside in the warmth of the house.
Wonder if anyone has had this happen.
thanks in advance
12-26-2018 10:42 AM
Nonsense I used my 5D, 5D Mk II and 5D Mk III at well under 0 degrees centigrade. Keep a spare battery in your inside pocket and they are good to go at temps below what I am good to go in!
12-27-2018 10:14 AM
@ebiggs1 wrote:Nonsense I used my 5D, 5D Mk II and 5D Mk III at well under 0 degrees centigrade.
I'm with Ernie. I've used all of my Canon cameras at temperatures well below freezing. Where I live, you can't avoid it. But if I'm wearing a heavy coat, I do try to keep the camera inside the coat when it isn't actually in use.
12-27-2018 10:54 AM
I have been on ten day shoots in the Colorado mountains and other cold locations where it didn't get above 0C the entire time. Everything from my F1n to my 1DX has worked flawlessly. Don't worry about it, it will be fine.
12-17-2018 09:13 AM
There are a lot of opinions on what someone thinks is cold. Best to give us a temperature range the problem shows up at. Also just how long does it perform properly before the cold has penetrated into the camera?
12-18-2018 10:14 AM
Try a brand new battery. A brand new Canon battery!
12-18-2018 07:57 PM
I would say that about 10 mins of cooling at -7 celcius would be where the issue would start.
Thanks
12-20-2018 10:11 AM
"Try a brand new battery. A brand new Canon battery!"
12-26-2018 01:02 AM - edited 12-26-2018 01:03 AM
None of the 5D series cameras can operate under 0C. The recommended temp range is 0 - 40 according to the manual. You may need some kind of "warmer" probably 🙂
12-26-2018 10:42 AM
12-27-2018 10:14 AM
12-27-2018 10:48 AM
I used it under 0C myself. It's just not guaranteed that everything will be properly working, especially for long periods of time. For example a while ago on my A99 I had exposure issues. I know only some Olympus MFT cameras are advertised to work at -10C.
12-27-2018 10:52 AM
