02-17-2016 12:44 PM
Is it possible to include the shooting date in the image file number?
02-17-2016 01:55 PM - edited 02-17-2016 01:57 PM
Not in camera, but you can if you download files using EOS Utility, which came with your camera.
02-17-2016 02:24 PM
Thanks jrhoffman75.
Didn't think of that because I usually pop the SD card and copy from there which doesn't open the EOS Utility (I tend to misplace the USB lead for the camera).
Graham
02-17-2016 02:35 PM
02-19-2016 08:56 PM - edited 02-19-2016 09:09 PM
@GRAHAM1 wrote:Is it possible to include the shooting date in the image file number?
I have used computers for decades. There is a simple rule of thumb to use when it comes to naming files and directory/folder/path names where you store the files. It goes like this.
If the folder path name, combined with the filename, does not tell you what is in the file, then you need to re-think the way you name files, folders, and sub-folders.
In other words, if you must open a file to figure out what is inside of it, then what you are doing is falling shor to the mark, and you need to re-think your naming strategy. It is better to use sub-folders, just like you would with an actual filing cabinet, than it is to throw everything into a single folder within your filing cabinet. For example.....
This is the folder that contains the second set of panorama shots that I took on the indicated date. The "PAN02" folder is a subfoder containing JPEG files. The immediate parent folder, 2015_10_06, is the date that I shot the images, and it contains only the RAW files downloaded from the camera.
I created this sub-folder , PAN02, of JPEG files using a batch file process with Canon's DPP software.
Hope this helps.
02-28-2016 01:53 AM
02-28-2016 02:01 AM
