Canon 5D Black Corners on Photos
JasonR
I recently got a Canon 5D Mark 1 (Classic) and I am using the Canon EF 28:135 Lens that came with my Canon 40D. Using this lens I am getting black corners on all of my photos that I shoot. My Canon 50mm lens works perfectly as well as my EF 70:200 lens.
What's going on here? It is not an EF-S lens and it works perfectly on my 40D but not 5D.
10 REPLIES 10
Peter
1. Filter?
2. Wrong lens hood?
3. Sample?
wq9nsc
When you say black corners, are they truly black or just greatly reduced in brightness compared to the rest of the frame?  This lens does have significant vignetting which is far more obvious on a full frame body.
Is there a non-standard lens hood on it?
Rodger
Thanks for the reply, I will post some pics when I can. I do have a UV/protector on it as well as a Polorizing filter on it. The lens hood is a collapsible rubber hood and it was collapsed when taking the photos.
Thanks for the reply, the corners in my opinion are truly black but do soften some as you get closer to the center of the image. The lens hood is a collapsible rubber one that was collapsed when I took the photos.
Peter
Remove all filters and the lens hood.
That lens hood is probably the problem.  As advised, stop using it.
Thanks Peter, that was going to be the next thing that I try as soon as I can get home.
Also stop the double filtering. If you're using a polarizer, you don't need a UV filter.
Bob
@Waddizzle, are you suggesting there is something wrong with the lens?
