12-05-2020 01:24 PM
I have a Canon eos 90d and the photos are over exposed when shooting in non live view mode (when switching back-and-forth between live view and viewfinder modes; the ISO doubles), or another words looking through the viewfinder, the ISO will double. There's no exposure addition or subtraction on exposure stops. I am confused please help!
12-05-2020 01:50 PM
If you have not already downloaded a copy of the full User Manul from Canon Support, then I suggest that you do so.
Without knowing what lens are using, what your camera is looking at, what camera settings you are using, there is no way anyone could possibly advise you on what is going wrong for you.
Please try to provide enough informatiuon so that someone else can duplicate your problem.
12-05-2020 02:42 PM - edited 12-05-2020 02:44 PM
Are you in Auto ISO mode?
Forum member ray-uk posted this on DPReview a few years ago:
12-05-2020 05:13 PM
My apologies.
I have the Sigma 18-35 F1.8 DC lens. It is in auto ISO mode for all these modes: SCN, A+,P,Tv,Av. I am looking through the manual. I just haven't found out why it seems to overexpose or add exposue/iso when looking through the view finder. My intuition makes me think it's a simple setting somewhere. Thank you for the help, much appreciated.
12-05-2020 05:31 PM
Thanks for that post. Not sure if that's the case here, it's good insight.
12-05-2020 05:35 PM
@vizualequalizer wrote:My apologies.
That setup and camera setting info is a good start. Could post a sample of each shooting scenario: Live View vs Viewfinder?
What are you photographing? Are you using a tripod? What metering mode, and AF mode, is used for Live View? Same question for shooting through the viewfinder.
When you post the photos, you can use Canon DPP4 software to reduce the files size, and include the EXIF data. The EXIF data can dell us what is happening. But, there are a couple of things it doesn't tell us, though. It will tell us "1 Pt AF", but t does not tell us which AF point you sued.
12-05-2020 06:15 PM
Thanks for taking the time "Waddizzle" and for the instructions, much appreciated.
I saved them as EXIF JPG using DPP4, hopefully that was in line with what you requested regarding EXIF data.
Both Handheld:
Metering mode for OVF (Optical View Finder) is: evaluative and focus is: AI Focus.
For Live View, metering is: evaluative and for focus: AF 🙂 (Face) + [] (Tracking).
Live View (left or top) vs. OVF (right or bottom).
12-05-2020 06:18 PM
12-05-2020 07:38 PM
Thank you much for the help, not sure these pictures posted correctly, I saved them using DPP4 to included EXIF data, but how are you going to see that from the files posted in my answer? Do I need to include the data separately? Thanks
I do not see any EXIF shooting data.
The images are extremely small, too. Using a non-Canon lens should not be a factor, not at least when it comes to exposure. One seems quite over exposed by at least one stop, while the other is under exposed by at least one stop. Hard to tell with such small images.
Try this experiment outdoors, if you can. You could be looking at a light flicker issue associated with the artificial lighting.
12-05-2020 07:39 PM
Hello.
I can't download these files as JPEG; they show up as an unknown file type only 20kb in size.
I did some experimentation with my camera (a 1D series).
I set a fixed ISO of 1600 in Av mode, thus the only variable would be shutter speed. Evaluative metering for both modes. Center single point focus for both modes.
One mode gave a SS of 1/13, the other 1/20.
That seems to support the DPReview post,
