07-27-2017 07:15 AM
Hi, ive just upgraded to a 7dmk2 ( what a great piece of kit) from my 660d and a borrowd 7d, and other than the steep learning curve on the AF system im getting along just fine, except one little issue, which im sure is operator error.
I have a x2 converter which on all camers ive used works with out issues, it meters focuses etc and images would come out balanced clean focused etc, on the Mk2 for what ever reason i have to under expose by at least 2 stops to get an image that is usable, if i use the onboard meter and centre the exposure they are completley blown out.
It makes no difference if i use it on any lens i have, from the 50mm 1.8 through to my 70-200 2.8
Any ideas on what the issue could be?
I know the real soultion is to get larger lenses but thats not in the budget just yet.
Thanks for the help.
07-27-2017 07:46 AM
Sounds like it's a non-Canon product. Did you check on manufacturers site for a notice? Maybe a chip issue.
07-27-2017 08:28 AM
07-27-2017 08:51 AM
07-27-2017 09:02 AM
@Clouts11 wrote:
It is non Canon, but as it works on the others and even a friends 5Dmk2 can anyone see a reason why this would occur?
I think John probably had the answer: your 3rd-party 2X converter is incompatible with the camera. The manufacturer may have gotten it right for earlier Canon cameras, but not for the 7D2, which probably wasn't out yet when the converter was designed. You can call Canon Support, but I'll bet they'll tell you the same thing.
07-27-2017 09:19 AM
@RobertTheFat wrote:
@Clouts11 wrote:
It is non Canon, but as it works on the others and even a friends 5Dmk2 can anyone see a reason why this would occur?I think John probably had the answer: your 3rd-party 2X converter is incompatible with the camera. The manufacturer may have gotten it right for earlier Canon cameras, but not for the 7D2, which probably wasn't out yet when the converter was designed. You can call Canon Support, but I'll bet they'll tell you the same thing.
Don't call Canon support. Call the manufacturer of your Teleconverter, they will tell you the same thing, but, might have a way to upgrade your Teleconverter.
