11-22-2014 12:26 PM - edited 11-22-2014 12:55 PM
Recently purchased a new &d MKii. (yesterday) Using a Conon 100-400 lens and taking pictures high speed and continuous with the shutter release button and then looking at the in Lightroom all the pictures "grayed out" about 30% on the right side of the photo. How can this be. This is the 8th canon camera that I have owned and used. I have never seen this before.
Steve
11-23-2014 05:22 PM
Aperture priority.
11-23-2014 05:30 PM
Sorry, I only shoot RAW. The picture was a tree outside using only available light. No flash.
11-23-2014 05:59 PM
11-23-2014 06:35 PM - edited 11-23-2014 06:35 PM
@PaulSoebekti wrote:
And can you post the exif information please?
Exif is in the image:
Manufacturer: | Canon |
Model: | Canon EOS 7D Mark II |
XResolution: | 72 |
Y Resolution: | 72 |
Resolution Unit: | Inch |
Software: | Adobe Photoshop Lightroom 5.7 (Windows) |
Date Modified: | 2014:11:21 18:39:36 |
MetaTools Info Offset: | 214 |
Exposure Time: | 1/500 s |
F Number: | f/5.6 |
Exposure Program: | Aperture-priority AE |
ISO Speed Ratings: | ISO 4000 |
Sensitivity Type: | 2 |
Recommended Exposure Index: | 4000 |
MetaTools Version: | 2.30 |
Date Created: | 2014:11:21 12:44:42 |
Date Digitized: | 2014:11:21 12:44:42 |
Shutter Speed: | 8.966 s |
Aperture Value: | 4.971 |
Exposure Bias: | 0 EV |
Max Aperture Value: | 5 |
Metering Mode: | Spot |
Flash: | Off, Did not fire |
Focal Length: | 400 mm |
Time Created Subsec: | 18 |
Time Digitized Subsec: | 18 |
Color Space: | sRGB |
Focal Plane X Resolution: | 6086.763 |
Focal Plane Y Resolution: | 6090.15 |
Focal Plane Resolution Unit: | Inch |
Custom Rendered: | Normal process |
Exposure Mode: | Auto exposure |
White Balance: | Auto white balance |
Scene Capture Type: | Standard |
Body Serial Number: | 032021004098 |
Lens Specification: | 100-400mm |
Lens Model: | EF100-400mm f/4.5-5.6L IS USM |
Lens Serial Number: | 0000000000 |
Compression Method: | JPEG (old-style) |
JPEG Interchange Format: | 874 |
JPEG Interchange Format Length: | 12454 |
11-23-2014 06:40 PM
11-23-2014 08:08 PM
Totally outside away from anything and the first 2 or 3 and the last were OK.
11-23-2014 08:13 PM
Thanks. The original picture was RAW and converted to JPEG to email. The camera is being returned monday. I have a 5d MK III for a back up and sold my 7D on ebay-why-not a clue! Should have kept it.
11-24-2014 03:17 AM
Any chance of making one of the offending Raw files available?
11-24-2014 08:55 AM
You guys are overthinking this. The camera apparently has a shutter problem or a light leak. Trying to figure out which is a waste of effort. If the problem is repeatable, sending the camera back for inspection and/or replacement is obviously the correct course of action.
11-24-2014 10:18 AM
@RobertTheFat wrote:You guys are overthinking this. The camera apparently has a shutter problem or a light leak. Trying to figure out which is a waste of effort. If the problem is repeatable, sending the camera back for inspection and/or replacement is obviously the correct course of action.
And what do people who might subsequently have an interest in this thread learn from that attitude, Robert?
Time spent trouble-shooting and trying to understand an issue is never time wasted.
