01-21-2015 06:42 PM
01-21-2015 07:08 PM
I used Q-tip and very little 99% isopropanol to clean the contacts. Not sure if it is right. But it works.
01-22-2015 09:42 AM
It is something that is rarely a problem. The gold contacts are fragile as the gold is very thin. If you change lenses regularly, the contacts are probably "clean". Why do you think they need to be cleaned?
01-22-2015 10:13 AM
When set on shutter priority or aperture priority, the camera will frequently not fire. A message (Err 01) appears on the screen that says communication between lens and camera is faulty. Clean terminals. If I switch to a "P" setting, it will often work fine for a few exposures, then I get the same message. If I switch back to "Av" or "Tv", again it will work for a few exposures but then the message reappears. It seems to happen more with the 17-85 mm lens than the 10-22 mm.
01-22-2015 10:45 AM
Might I suggest it is the lens and not the camera? Has the lens been dropped or some other malady? Recently? Hmmmmm.
If you must clean use a qtip and denatured alcohol and be gentle. Do not use a pencil eraser like some suggest.
You should clean the lens at the same time. Hope it cures the problem for you.
01-22-2015 03:16 PM
This problem happens several times to my different camera combinations when I used the gears in very humid places. Several times in asia -different countries and twice in San Juan.
Watch out also for the temperature difference indoor and outdoor. This will cause condensation and thus the problem.
01-22-2015 04:54 PM
It could well be the lens. But, it hasn't been dropped or even handled roughly. I've used the lenses for many years and only recently has the problem arisen. I have been reluctant to use any solvents on the contacts, but I will try a bit of alcohol. Do you think I should only clean the lens contacts and not those in the camera?
01-22-2015 04:57 PM
Are you thinking that condensation might appear on the surfaces of the contacts where I could see it or perhaps dry it out with a hair dryer? Or, are you thinking moisture may have gotten inside the lens somehow?
01-22-2015 06:19 PM
I cleaned both. 99% alcohol evaporated in seconds. Never any harm. If you worry, don't do it.
01-22-2015 07:08 PM
I saw condensation on the surface of the rear element. I then returned to the hotel room with a/c turned to maximum. The lens rear element dried up in a short while. No more error. But bear in mind, if you go from a cold area to a warm area or vice versa, condensation will reappear.
That may be a rare case but in some places. Humidity will kill your camera gears. Google condensation causing damage to camera - even the expensive 5D3.
http://www.canonrumors.com/forum/index.php?topic=16121.15
I wouldn't use a hairdryer. you will risk blowing something into the sensor. overheating may cause damage to the electronics.
