05-20-2014 01:04 PM
My question concerns program mode with 60d/ 18-55mm stm lens - my understanding is that in program mode the camera tries to use a MINIMUM shutter speed compatible with focal length selected, ie at 18mm...1/18sec...55mm...1/55sec approximately. When I tried it, at 18mm it selected 1/30sec which is ok, but at 55mm it selected 1/15 sec!!! way too slow for handheld at 55mm. Does anyone have any ideas on this. I put ISO on 'auto' so it would not be a factor. Thanks as this is driving me nuts!
05-20-2014 01:30 PM
I have not come across anything that documents the algorithm for how Canon program mode choose the exposure settings.
It's unlikely that it is as simple as always going for the minimum shutter speed and a quick test with my f/2.8 lens attached (while using Program mode) reveals that it's often happy to use a middle aperture even when a lower aperture would allow for a faster shutter speed.
My "guess" (and this is purely a guess because as I said... I've never seen anything that documents how the algorithm works) is that it's looking for "safe" exposures. In other words... avoid extremes. Try to get the shutter speed fast enough to deal with the focal length of the lens when possible. I suspect it tries to avoid shooting with a wide-open aperture and also tries to avoid shooting with an excessively stopped down aperture. But this presumes there's enough light that the camera has lots of adjustment latitude.
If you back the camera into a corner by depriving it of light to see how it behaves when it's desperate to get anything at all... you may see different behaviors.
Don't forget that the camera offers "program shift" and that's sort of the whole point of Program mode and what separates it from shooting in full auto. In "program" mode the camera comes up with an initial set of exposure settings just as in auto. But unlike auto, you can roll the main-dial (the one near the shutter button) to scroll through all the equivalent exposures which are also possible given the metering... as well as using the rear dial to use exposure compensation.
05-20-2014 02:26 PM
I think you are missunderstanding the Program Mode (P on the dial). Program mode is just a fully automatic shooting mode but you can override many different settings like TCampell said.
What are you referring to (I think) is a feature of the AUTO ISO. Newer Canon cameras has an option in AUTO ISO where you can choose when the camera bump up the ISO (Not sure if 60D has this function). Under this options, you'll have several settings (1/125, 1/250, 1/100, AUTO, etc.). For example, if you choose 1/125, then the camera will increase the ISO whenever the shutter speed fall under 1/125 to maintain the exposure. If you choose AUTO setting, the iso will be increased based up the reciprocal of the focal length.
05-20-2014 03:59 PM
@hsbn wrote:What are you referring to (I think) is a feature of the AUTO ISO. Newer Canon cameras has an option in AUTO ISO where you can choose when the camera bump up the ISO (Not sure if 60D has this function). Under this options, you'll have several settings (1/125, 1/250, 1/100, AUTO, etc.). For example, if you choose 1/125, then the camera will increase the ISO whenever the shutter speed fall under 1/125 to maintain the exposure. If you choose AUTO setting, the iso will be increased based up the reciprocal of the focal length.
I'm pretty sure only the 1Dx, 5d3 and 6D offer that. Although, Magic Lantern also has similar functions and I believe it allows more customization.
05-20-2014 05:41 PM
I've never ever read that the camera would use 1/focal length or faster either. It may have on some occasions but I doubt it's a built in function.
05-20-2014 07:18 PM
@cicopo wrote:I've never ever read that the camera would use 1/focal length or faster either. It may have on some occasions but I doubt it's a built in function.
It's a built-in function for Auto ISO. You can read more HERE
Here is an excerpt:
"Until now, one problem that kept many pros away from Auto ISO was that there was no meaningful control over how slow a shutter speed might be selected in low-light conditions. But with Canon’s recently introduced SLRs, the photographer can tailor Auto ISO to give exactly this type of control. A separate menu entry, Minimum shutter speed, provides the following settings:
05-20-2014 07:53 PM
Good thing we hope to learn something new every day because I've done it now. Thanks.
05-21-2014 10:44 AM
That's really good to know. I'm one of those people who _never_ uses auto-ISO because I have no control over it. I tend to learn about and use most of the features of a camera, but up until you posted this, had no idea that this was available on my 5D III. I think I may just have to give this a test spin and see how it works.
Thanks!!
05-21-2014 10:57 AM
I never used Auto ISO until I got my 6D, not I use it all the time. It's really quite good. If they put in ability to do exposure compensation in Manual mode I'd probably use it 100% of the time I wasn't doing studio work.
05-21-2014 11:06 AM
I used auto ISO on my 1D4 for a while but abandoned it when it over rode my flash settings & selected the Max ISO for all my photos one night.
