5d Mark IV downloading 2 versions of the same RAW file
WickWelsh
My 5d Mark IV has recently started downloading two versions of the same shot when I import via Photoshop. I only have one card onboard and the camera shows only one version when I review in camera. I've updated the firmware to 1.33 today, but that doesn't fix the problem.
Any ideas?
10 REPLIES 10
jrhoffman75
Can you provide more info? Do you perhaps have RAW + JPEG selected in the image selection?
kvbarkley
This has sometimes happened to me with Image Capture. I find I have to re-format the card in the camera.
Hi John,
I've got RAW set to highest quality, JPEG turned off, as is Dual RAW. I only have a single card in camera.
Thanks for the suggestion. I just tried that but still get the same issue
WickWelsh
Just ran the download using EOS Utility 3 and it worked fine, so looks like an issue with Adobe Bridge
ebiggs1
Not saying it isn't a fault in Bridge but Bridge it has never done that with my cameras.  I have used it for years but I don't have the latest version. I would do a format and/or replace the CF card(s).
In the future never upgrade FW just because you are seeing a malfunction.  Find out first if the FW is the culprit by reading the upgrade details and what it corrects. Upgrading FW on a malfunctioning camera can be really bad.
If the FW simply updates a language you don't use or a lens(es) you don't have there is no reason to do it.
EOS 1DX and many lenses.
Thanks, I did the FW update because others with a similar problem (admittedly on Mac) suggested it. I also formatted the card first but no luck. I will try other cards though, so thanks for that suggestion.
Lightroom allows a copy to be downloaded during import. Maybe Bridge does that and it got inadvertently selected.
ebiggs1
OK, I am using a Windows machine. Perhaps it is an issue with Bridge and Mac OS.
