04-07-2021 07:27 PM
04-08-2021 09:53 AM
04-08-2021 09:53 AM
04-08-2021 10:03 AM
04-08-2021 10:22 AM
Did you actually reset the camera as John requested? I have heard of other cases where brand new 5D Mark IV bodies were shipped with it set for back button AF, probably done during a testing protocol before it was shipped. If set up that way, then it won't AF when the shutter release button is pressed half way.
The only other setting I can think of within configuration that would impact AF operation would be what the camera does under the AF configuration choice of what to do when "AF is impossible or far out of focus". I believe this option is on the fourth screen under the AF configuration tab with your 5D IV and when set to off with some lenses, the AF may not function properly to try to obtain focus.
But resetting everything back to factory as John suggested should set both of these back to the non-problematic default settings.
Rodger
04-08-2021 10:35 AM
04-08-2021 10:39 AM
04-08-2021 10:40 AM
@areejbashir wrote:
Thank you John for that tip, I reset the setting buts no change. But the only thing with Green Square Auto is I’m not able to set the aperture, shutter speed and iso to my liking
Yes, let's test the lens by allowing the camera to adjust the settings in Green [A] Auto mode.
04-08-2021 10:42 AM
@areejbashir wrote:
@rodger thank you for your help. I reset everything and made sure the “lens drive when AF impossible” is on. But still nothing. It works when it’s in Green Square Auto Mode, but that’s not convenient for me unfortunately.
Not sure what else I should do
If the lens works in Green [A] mode, then there is something in your camera settings causing the problems.
04-08-2021 10:43 AM
04-08-2021 10:45 AM
