5D Mark IV with 50mm lens
areejbashir
Just received my Mark IV, but for some reason my 50mm lens AF (Auto Focus) won’t work. It won’t focus on the pointed area, it won’t even bleep. What could be the problem?
Thank you
29 REPLIES 29
jrhoffman75
Try pressing the AF-ON button. If it focuses then you need to clear all custom functions. Check your manual to see how.
areejbashir
@Barkley ahh okay! Sorry my misunderstanding, I’m very bad when it comes to technical things and everything just confusing for me.
Yes the camera has the (AF-On) button at the top right corner of the camera, right next to the view finder, if that’s what the Back Button Focus is. Okay so the focus works now if I press The (AF-On), but I do have to press it every time for it to focus on something new, is this another problem or is that how it works?
jrhoffman75
As I posted above, go into your manual and see how to clear all custom functions. The previous owner decoupled focusing from the shutter button. It is important to clear all custom functions since you don’t know what other settings might be active.
The Custom Controls menu is also accessible from the Quick Control Screen Menu when you press [Q} button.
This Custom Controls menu has its' own reset function that needs to executed.
areejbashir
I think I’ve got! Thank you all so much for your help, really appreciate it
Congratulations!
You bought a used camera?  For reasons that you have just experienced, it is a good idea to go meticulously go through every menu and reset it.  You want the entire camera reset back to a known state, just as it came from the factory.
[EDIT]. As you go through each menu item, if a menu item opens up to its' own sub-menu, then it probably has its' own separate reset that you need to use.  A good example is the Custom Controls menu that you seemed to have reset.
It has been rumored that if you remove the battery, close the battery door, turn on power, and then hold the shutter fully pressed for at least 10 seconds....the camera should completely reset itself, time/date and all.
areejbashir
Thank you!
Yes, it’s a used camera.
I’ll do all your suggestions and hopefully everything will function normally again.
Thanks
areejbashir
Want to thank everyone for their help. Turned out the solution to my problem was a simple change in the control settings. Even after resetting it wasn’t working to how I wanted.
The solution :
Menu - Custom Function Setting ( the Orange menu) - Page 3 - Custom Controls - Shutter Butt. Half-press - and highlight the Metering and AF option !
Glad you are all set.
You have a very powerful camera - spend some time with the manual and YouTube tutorials to maximize your ability with the camera.
areejbashir
Thank you John! That’s a good idea. Was such a silly problem I feel, and I think I was just overwhelmed haha.
