5D Mark IV: Bracketing Issues
ac73
I've done the same bracketing for years and have never come across this issue? My brightened brackets are all the same exposure. I tried with 5 and 7 exposures - I'm getting my darker shots as usual but all of my overexposed shots are at 30" shutter. I'm not sure what I'm doing wrong to not have it start lower so it has the chance to brighten?
Settings: Canon 5D Mark IV, Av, 8.0, ISO 100, 2 sec timer. 4,2,0,2,4. Increments: 1/3. Sequence: 0-+ Shots: 5
I've never had this issue before. I've tried in several rooms and it's all the same? Suggestions?
ac73
Raising the ISO was the simple solution I needed - worked great!
3 REPLIES 3
Waddizzle
The camera isn’t capable of shutter speeds slower than 30 seconds.  Never has.
nipo535darly
Hello,
Switch to Manual (M) Mode
Set ISO and aperture manually
Then bracket shutter speed manually across your desired exposure range (you can do this with AEB too)
Gives you full control and lets you avoid hitting the 30" ceiling unexpectedly.
Raise ISO Slightly
Try ISO 200 or 400 to avoid hitting the 30" max exposure
This shortens shutter time required for the brighter shots
Widen Aperture Slightly
If possible, go from f/8.0 to f/5.6 to let in more light without compromising depth of field too much
Use Bulb Mode + Intervalometer
If you really need brighter exposures beyond 30”, switch to Bulb mode and use an intervalometer or remote trigger to manually time longer exposures
Hope that helps
Best regard,
Nipo
ac73
