04-19-2021 04:55 AM
Hello everyone, so I just sold my 80D with 18-135mm Lens because I wanted something smaller with around the same power and quality ( and similar lens) , I loved the camera, but I stopped using it because size.
I had my aim on the RP , mirrorless, compact and Similar to 80D in some aspects , so I called canon loyalty program , told them about the old t3i I had ( girlfriend camera ) and got a 20% discount on the RP with 24-105 kit lens ,
The camera just arrived , I haven't opened it because I'm still hesitant that this lens won't give Me the same range and versatility that the 18-135mm gave me So I was considering getting the m50 with the 2 lenses so I could get compact camera with longer range and versatility But since I already got the RP at an amazing price , what options to I have to get more zoom, the 25-250mm lens is extremely expensive
Has anyone been in this dilema themselves and could give me some insight ? Btw I'm an enthusiast photographer and professional visual artists , that is the reason I need a quality camera
04-19-2021 10:10 AM - edited 04-19-2021 10:13 AM
The M Series is rumored to be a dead end. I recommend you do your own reseach.
With that said, The RF 24~105 has a constant f4 aperture, is weather sealed and has better coatings than the 18~135.
Comparitively, you are jumping all over the board. EF-S, RF and Cine-Servo.
I did own the 18~135 paired with a T6s. It was a good lens and performed well. If I owned a mirrorless body, I would attempt to stick with RF glass. If you want quality, you're going to have to spend some money. Also keeping in mind, that while compact, the RP is a budget mirrorless camera. Versatility wise, it supports EF and EF-S glass with an adapter, but using RF glass is what I would recommend with an R body.
You are now without a camera, but have a new RP sitting in its box. If you have that much remorse about the RP, maybe you should have stayed with the 80D. There are going to be pro's and con's no matter what your decision is. I would have opted for the 24-70 f2.8 over the 105 f4. It costs more for a reason. The f4 however, will get you by in the majority of situations. Body's come and go, but lenses are what matter, You are going to replace that RP and when you do, having the 24-70 in f2.8 (considered by many as one of the best walk around lenses avaialble) would be my choice. I don't think I made this any easier for you, and probably have only givien you more to contemplate. Sorry for that.
EDIT... want to add one more thning. If it came down to a M or R series, it would be R all the way.
04-19-2021 12:00 PM
I think the 24 to 105 is the kit version that comes with the EOS RP. If so, that's going to be the Canon RF 24-105mm f/4-7.1 IS STM.
IMO, the 18-135mm was the better of the two, unfortunately.
04-21-2021 10:49 AM
"I wanted something smaller with around the same power and quality ..."
It sounds like you are a good candidate for one of the better Powershot camera models. The PowerShot G7 X Mark III, for example. It is small and takes amazing photos. But it is only one model in the Powershot line for you to consider. Although I use a 1 series, very big and very heavy, I always have my Powershot G1x with me.
04-21-2021 10:51 AM
"... but I stopped using it because size."
Any camera you use is far better than the one you don't use. Check out the Powershot line.
04-21-2021 10:53 AM
"The M Series is rumored to be a dead end."
I agree. Not a good line to get into right now, IMHO. However, an M will always work as well tomorrow as it does today.
