3 X 3 Grid In 7D Viewfinder
Eliza2018
I have had a 7D for several years and it seems to me that, in the past, it displayed the 3x3 grid in the view finder, as it does on the LCD screen, which seems to be completely unavailable to me, now.  Is there any way to force the camera to display it?
14 REPLIES 14
@Eliza2018 wrote:
@RobertTheFat wrote:
@Eliza2018
  I think you may be trying to follow the rule too slavishly.
I agree, but I am taking courses and have to meet course criteria. I did do some more reading and apparently, the multi-line grid in the optical view finder is more for architectural photography, to keep the picture level and buildings vertical. I did find an interesting article about creating your own grids, if you have Magic Lantern installed. It was an interesting exercise, but, of course, they can be viewed only on the LCD. It was an interesting way to waste time.
I suspected as much, but I figured I'd better stop short of encouraging you to call out the course instructor. Such actions tend to do more harm than good.  Smiley Wink
Bob
You should be able to guesstimate from the existing grid. Actually, the gaps in the focus area are pretty close.
Another thing to do is to zoom out a bit and then crop to get the exact composition you want.
ebiggs1
"It was an interesting way to waste time."
So is Magic Lantern, don't do it.
EOS 1DX and many lenses.
Is ML problematic?  I installed it because I wanted to do some time-lapse photography and it worked well.  When I don't want to use it, but forget to press the Set button while booting, the ML menu can interfere. Other than that, it seems okay.
"Is ML problematic?"
You have been lucky.  When it works it is fine. When it doesn't, it is a nightmare. If, when, it does, your camera will turn into a brick. Only Canon service can repair it.
