07-16-2018 06:14 PM
I'm going to ask an imperfect question, so bear with me, but I think it will lead to the answers I am looking for. Iv'e started a new thread but this topic arises in many other threads in different bits and pieces.
Let's take a lense like the EF 16-35 where we have the choice of f/4 with IS that (I believe) is rated at something like 4 Stops, and the f/2.8 with no IS.
Let's further assume that I'm going to do walk-around city/street shooting where I will most frequently shooting WITHOUT a tripod.
While the 2.8 affords me faster shutter speeds, I am afraid that the shallow DOF will be undesirable in many shots. Therefore, for mostly handheld shooting where shallow DOF is not desireable, would one be better off with the IS with a min of f/4 given shutter speed (for these kinds of pics) is not the major concern?
I know there are a lot of variables still left unexplored, so the answer will likely still be "it depends" but hopefully this the above scenario is enough to help me start understanding the real-life tradeoffs between a smaller aperture with IS vs a larger aperture without.
Thanks
07-16-2018 06:22 PM
If you don't need f/2.8 than IS is always better.
What camera? A 16-35 is wideangle on a FF camera, so IS is not as necessary. It is a medium lens on Copped frame which is more likely to need IS.
07-16-2018 07:28 PM
It is a wide angle lens. With a fast shutter, the lack of IS won’t matter. Besides, the only times I use f/2.8 with my 16-35 is in close quarters when I am indoors. Otherwise, I am shooting at f/5.6 to f/8 outdoors on bright sunny days.
07-16-2018 10:23 PM
How often do you think you would be shooting with a really slow shutter speed? IS is nice but with most lens I would take 1 stop over IS any day if that was the choice because I am often shooting action where I need a fast shutter speed anyway so IS is less useful and important.
With a 16-35 even if you close down the lens to maximize depth of field on most recent DSLR models you can bump the ISO up quite a bit before noise and lack of DR become a problem which is often preferable to choosing an abnormally slow shutter speed.
I would also take a close look how the two choices compare for IQ across a wide range of conditions while paying particular attention to typical shooting conditions you envision. The 16-35 is a lens I have never used so I am not familiar with how the various versions behave in terms of wide open sharpness, espescially across the full area of the sensor but that is something I would look at closely before buying.
I guess I am "old school" since I started shooting way back in the film days when IS wasn't available so it is something I like having but for me and my typical usage it isn't the most important criteria while for others it will be.
Rodger
07-17-2018 01:08 AM
@kvbarkley wrote:
What camera?
1DX II
07-17-2018 01:15 AM
@Waddizzle wrote:It is a wide angle lens. With a fast shutter, the lack of IS won’t matter. Besides, the only times I use f/2.8 with my 16-35 is in close quarters when I am indoors. Otherwise, I am shooting at f/5.6 to f/8 outdoors on bright sunny days.
Thanks. Only part of my question is practical; the bigger reason is trying to learn about the tradeoffs. Toward that end... in poor light scenarios, the only way to get the faster shutter speed is with f/2.8, which concerns me as too shallow DOF for a lot of shots. More specifically, I was shooting a prom event using my 70-200 at f/2.8 and had several shots where the DOF was so shallow that in a side-by-side shot, with one person slightly back, the back person was out of focus while the front person's face was tack sharp. I also know this is my fault for not understanding (quickly and in the moment) how DOF is affected by zoom and distance to target. As I said, just trying to learn.
07-17-2018 01:24 AM
@wq9nsc wrote:How often do you think you would be shooting with a really slow shutter speed? IS is nice but with most lens I would take 1 stop over IS any day if that was the choice because I am often shooting action where I need a fast shutter speed anyway so IS is less useful and important.
Thanks, Rodger. 90% of my historical shooting is fast-action sports (hence, the 1DX II love affair I have). For sports, I've very comfortable with my 70-200 f/2.8 and my 24-70 f/2.8. Shooting groups of people and couples is proving to be new training ground for me with the DOF stuff frustrating me as I learn. Practice is required, but in addition to field practice, I like to understand some of the more theoretical stuff behind this stuff.
To answer your question specifically, I imagine that if I'm doing city-walk type shots, it might be slower shutter speeds quite a lot if I want good DOF but in lower light.
Agree. I upgraded to the 1DXII from a 10yo 7D M1 and was absolutely thrilled with everything about the DR and ISO sensitivity. I just took some shots last night at a very dark restaurant and with a little NR in Lightroom, 25600 shots were perfectly usable for family viewing purposes.
I will definitely do some renting first, and because it's a newer type of shooting for me, I have a lot to learn before I even know the typical conditions I will experience. Like I said, sports shooting is really the only type of photography with which I am very comfortable.
Thanks again for all the help.
07-17-2018 02:27 AM
Focal length plays a major part in depth of field. For 16-35 range, unlike the 70-200, the depth of field at f/2.8 is not that shallow. You really need to look into hyperfocal distance to have more understanding and control of your DOF.
@Granted that you don't usually use f/2.8 too often on a "landscape" lens but there are many cases f/2.8 comes in really handy. For example, take a look at this picture I took recently in Copenhagen - I was on a moving boat so I needed decent shutter speed. I also wanted ISO 100 - So I took this picture @ FL 26mm; 1/400; ISO 100 at f/2.8 - focussed at 30 feet which was the hyperfocal distance so I know that everything 15 ft from me to infinity will be in reasonable focus. Canon 5DSR, Canon 24-70mm f/2.8L II USM lens.
Similarly, below is a picture I took a couple of years ago in Kyoto, Japan - it was getting dark and I was without a tripod...I left my tripod back at the hotel because I had been walking so much during the day in 90 degrees , 90% humidity condition and I was exhausted. By late afternoon, I had nothing with me except the camera and lens. Same thing - focused at hyperfocal distance (40 feet)...decent DOF at f/2.8 - Canon 5D Mark III, Canon 24-70mm f/2.8L II USM; FL 31mm; 1/60; ISO 4000
07-17-2018 03:03 AM - edited 07-17-2018 03:04 AM
I have often [used] this link to select lenses and focal lengths before leaving the house.
http://www.dofmaster.com/doftable.html
It describes the hyperfocal distance, too.
07-17-2018 10:39 AM
Coach,
One more good reason to go with the f2.8 version is you already have a couple f2.8 lenses. I think it works out better if the lens stable is, well, stable. Make sense, all three lenses are f2.8 so there is no worry about switching when you are in an important shoot. Will this lens work? It will if the others did sorta thing.
You do need to learn more about DOF as it is not that shallow at 16mm on a 1DX. Think of this, my friend, if you don't need f2.8 and you own the f2.8 version, you don't need to use it. It has f4 just like the other one but if you need f2.8 and don't have it available, you are screwed. Do you want to give that fact up for IS that may be of little value anyway on a WA zoom?
No, no way, not never!
