07-16-2018 06:56 PM
I have recently started using a Canon 5D Mark ii full frame camera, and am looking for a budget lens to replace the Tamron AF 18-200mm that I used on my crop frame 60D.
I carry my camera with me a lot, and liked the Tamron as it did quite a good job for most circumstances.
I know it was a budget lens but I was quite happy with it until I could afford a better lens.
Can anyone suggest an alternative 'all-in-one' type lens that I can use with my full frame camera.
I will be looking to by a used lens as I don't have a big budget. so it will be a stop gap lens until I can afford to upgrade.
I do have a Canon EF 28-80mm lens that I am using at present, so I would consider something that would accompany this, but ideally I would like one lens to use whilst wandering around.
Any help would be much appreciated, Dave
07-16-2018 07:34 PM
How much budget are we talking about? Your camera deserves a quality zoom like the EF 24-105mm f/4L IS USM. You can find this lens as a refurbished model in the $600 USD range. Avoid auction sites.
I think the EF 50mm f/1.8 STM would be a great lens to have in your bag. Full frame EF lenses do tend to cost significantly more than EF-S lenses, because of their size.
I would suggest that you save up for the EF 24-105mm f/4L. Invest in one really good lens, an L series. Does not matter which one.
07-16-2018 08:50 PM
That would definitely be the kind of lens I would like but is out of my price range at the moment.
My budget for now is around $300
I am considering renting an L-series lens from my local camera store.
If my limited photography skills show a sufficient improvement with it, I will sell the 60D and Tamron Lens to finance buying an L-series.
Thanks for taking the time to answer my question, I appreciate it. Dave
07-17-2018 01:34 AM
I went down a similar path as you back when I first started to get more serious, and since then I've recommended people NOT go that same route. Knowing I what I know now, I would have kept my Rebel longer and invested in good glass first, before moving to the 7D. But, water under the bridge and I really wanted the 7fps back in the day.
Just my opinion, but given where you are now, I'd supplement your 28-80 with a good lens rather than further pursuing "cheap" lenses with a good camera body. The complement I would recommend is a 70-200 f4.0 L. Probably couldn't get it at $300, but I think with the new models out now, you could get the older models for $450 range. Just a guess though. My point is that if I were in your spot, I would take a used L lens in good condition over a new cheaper lens.
Good luck!
07-17-2018 02:59 AM
@Dave64 wrote:That would definitely be the kind of lens I would like but is out of my price range at the moment.
Like I said earlier, a really good lens to buy would be the EF 50mm f/1.8 STM. Be sure it is the STM version. You can buy it in the Canon Online Refurbished Store for less than regular list price, and still get a one year warranty.
The wide aperture, f/1.8, will teach you a LOT about photography.
07-17-2018 09:38 AM
I heard good reviews about Rokinon 35mm f/2.8 FE. it's not that expensive and might the one that you need.
07-17-2018 09:52 AM
07-17-2018 09:54 AM
"My point is that if I were in your spot, I would take a used L lens in good condition over a new cheaper lens."
Absolutely. There is no good reason the buy another cheap lens.
07-17-2018 07:24 PM
@vander wrote:I heard good reviews about Rokinon 35mm f/2.8 FE. it's not that expensive and might the one that you need.
The Canon EF 35mm f/2 IS USM is a MUCH better buy for the nearly the same price. It has a wider aperture, auto focus, and image Stabilization, all of which the Rokinon does not have.
And, the EF 35mm f/2 is a really sharp lens.
07-18-2018 08:57 AM
Thanks for the advice everyone,
It was all good, I don't need any more cheap lenses
As a result, I have just purchased a 24-105 F/4 L
It is second-hand , but was bought from a professional photographer, has had little use, and is in great condition.
I paid £310 (UK Sterling) which I think is a fair price.
Unfortunately at work at the moment, but am looking forward to using it at the weekend.
Thanks again
