10-22-2020 11:51 AM
So recently upgraded to a full frame camera, now I’m looking to add some glassware. I’ve been looking at the 17-40mm as well as the 16-35mm. My main question is what’s the major difference(if any)? As well which would you recommend for all around shooting?
10-22-2020 12:11 PM
Which 16-35?
10-22-2020 12:43 PM - edited 10-22-2020 12:44 PM
What lenses do you have now? Both the 17-40 and 16-35 are not really considered all around, general use, lenses. They are ultra wide angle lenses
For general use, most people go with a 24-70 or 24-105 zoom lens.
10-22-2020 03:39 PM
@MikeSowsun wrote:What lenses do you have now? Both the 17-40 and 16-35 are not really considered all around, general use, lenses. They are ultra wide angle lenses
Mike is correct.
If you are coming from a crop sensor camera it probably came with an 18-55 kit lens.
Remember that the crop sensor alters the field of view; an 18mm lens on a crop sensor camera ias equivalent to an almost 30mm lens on a full frame camera. Thus the 24-70/105 lens recommendation.
If you really want the 16/17mm coverage on the full frame body the 16-35mm f/4 is an outstanding lens.
10-23-2020 05:07 AM
I have the 16-35 F4 L and have no complaints. I use it for landscape and Milky Way photos. The photos are clean & sharp with vibrant colours. I can't speak on the F2.8 as I have never used it.
10-23-2020 09:12 AM
"I have the 16-35 F4 L and have no complaints."
I have the f2.8L not the f4 which I have never used. I admit I have just a single copy of the lens. I have a couple friends that are not happy with theirs so I believe it is not a single case. I do have one friend that is totally happy with hers. However, I sell photos and can not sell what my 16-35mil produces.
Canon makes the best lenses in the world. I only go for off brand for two reasons. One Canon doesn't see fit to make the lens I want. Example the 150-600mm super zoom. And, two, the 16-35mm. Some could throw the nominally high cost of most of Canon products as a good reason, too.
10-23-2020 09:25 AM
There are three versions of the 16-35mm f/2.8.
The "III" version is reported to be significantly better than the previous two.
10-23-2020 09:34 AM
"The "III" version is reported to be significantly better than the previous two."
I certainly hope so. I have the II version. I replaced it with the Tokina AT-X 16-28mm f/2.8 Pro FX Lens. I am not a Tokina lens fan but this lens is fantastic. It is my only Tokina and likely will be my only Tok.
10-22-2020 02:13 PM
10-22-2020 02:17 PM
