11-18-2024
02:52 PM
09:26 AM
I am a sports photographer who currently shoots on a Eos R and an ef to rf adapter that connects to my ef 70-200 f/ 2.8 L IS USM, the first generation of 70-200. My current lens has a foggy not sharp look to it during low light so I am looking for a different lens, I cannot send it in for repair because it is too old and they don't service them anymore. I cannot decide between the rf 70-200 and the ef 70-200. If anyone has any advice let me know! I am also looking at a 24-105 f/4 for the upcoming basketball season so if anyone has strong feelings about this lens please share.
11-19-2024 12:14 PM
Renting is a good play, it gives you the opportunity to use a new piece of glass and may help identify where the challenges are cropping up.
Are you going to go EF or R?
Let us know how it works out after you do the rental if you have time. It will be interesting to hear what you find.....
Good luck and enjoy!
R3 ~ R5 ~ R6 Mk II ~ R50
Lenses: RF Trinity and others
Adobe and Topaz Suite for post processing
Personal Gallery
11-19-2024 12:19 PM
As Marc noted, this is due to lighting. Unfortunately with sports we don't generally get to choose locations/poses and sometimes the lighting just sucks. On a football field, when you have strong downward angled lighting behind the player and a fair but lesser amount of front or side illumination, you get the effect you see in your foggy photo. Here are a couple of examples with the EF 24-70 f2.8 lens post game, both the same night, same field, post-game celebration but very different lighting where the players are strongly back illuminated and the second where the players are closer to the endzone and not directly backlit.
I have captured similar game photos with my EF 70-200 f2.8 IS III and no lens is going to make a difference, my favorite EF 400 f2.8 IS II will do the same under those conditions. You can improve things in post but nothing will totally get away from the issue, basically when lighting conditions really suck then that is going to have a major impact on the final image. I know for the fields I shoot where the problems occur and I try to avoid the problem angles at those positions but it isn't always possible.
Both photos with 1DX II and EF 24-70 f2.8 with very different results, the difference is in the lighting intensity and location. The washed out photo has already been heavily corrected for contrast in post, the original file is worse than your "bad lens" example.
Rodger
11-19-2024 03:49 PM
I am renting an RF heres another photo in good light let me know if you think its sharp, I honestly can't tell. https://photos.app.goo.gl/wKQPyuH9LMwhURnL7
11-19-2024 05:55 PM - edited 11-19-2024 06:01 PM
If it's the RF 70-200 2.8 I think you will be a big fan!
I'll start with, if ever you are in Chicago let me know so you can stop by and punch me. Hopefully you get the joke but when I review someone it's a little awkward. Hence you get the punch.
The image is pretty good, a little soft and the focus point looks to be on the jersey, the panthers text and the number look sharper then the eyes, that looks like your focus point. Also, you are a little over overexposed. What type of metering do you normally use?
Your stuff looks good, I think you are on a good path and have to tweak a couple things. I've been photographing both commercially and as a hobby for a long time, I still need to review and tweak. Sports photographers, professionals shoot a ton of frames to get their keepers so keep that in mind. How long have you had the passion for sports photography?
I also asked wq9nsc (Rodger) to circle back as he is a very good sports photographer that can add value.
I downloaded the image and tweaked it a bit in PS, just knocked the exposure down .55, just to compare.
Personal Gallery
11-23-2024 06:25 PM
Same settings same angle. First photo is with my lens second is with the rf lens I rented.
11-23-2024 06:26 PM
11-23-2024 06:27 PM
Same settings same angle. First photo is with my lens second is with the rf lens I rented. Clearly an issue with my lens
11-23-2024 06:47 PM - edited 11-23-2024 06:47 PM
The shot with that RF is tack sharp and the colors vibrant. Are the shutter speed, ISO and aperture exactly the same for both images?
Personal Gallery
11-23-2024 06:49 PM
Exactly the same settings.
11-23-2024 06:54 PM
Well that's a problem, now I'm leaning towards your thought, you have a problem with your lens. I should have asked earlier, maybe a did and missed it. Are you using a Canon adapter with your EF lens?
And by the way, thanks for coming back and following up!
Personal Gallery
