RF 100M Macro focus ring functionality in AF
sueze
I am using the RF 100mm macro on my R5. I have struggled with finding focus with it. I sent it in a month ago for Canon to look at it and they told me it is fine. I was told when shooting AF the focus ring does not work. That I need to switch to MF, find the focus I want and then switch to AF. What a pain!! I lot of the time doing that, the lens will then lose focus. I mainly shoot flower/nature with my macro. I am lucky if the AF finds any focus! Is it true the focus ring does not work when using AF?
NOT all RF lenses support MF override when in AF mode. The RF 100mm F/2.8L Macro IS USM lens doesn't support it per Canon. List of compatible lenses
Compatible lens list for [Electronic full-time MF] are shown below. As of March 2021
RF70-200mm f/2.8L IS USM (Firmware Ver 1.1.0 or later)
RF100-500mm f/4.5-7.1L IS USM (Firmware Ver 1.0.9 or later)
EF400mm f/2.8L IS III USM (Firmware Ver 1.1.2 or later)
EF600mm f/4L IS III USM (Firmware Ver 1.1.2 or later)
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
18 REPLIES 18
deebatman316
The camera by default ignores the focus when in AF Mode. The camera needs to be set to allow the focus ring to be used in AF mode. The setting in the camera is called Lens Electronic Manual Focus. This is set to DISABLE by default so set it to enable and make sure the camera is set to One Shot. If its set to Servo AF the focus ring is ignored by the camera. You would be fighting the lens' AF motor this has been a restriction since the first EOS film SLR the EOS 650 in 1987. The EF 300mm F/2.8L USM lens released in 1987 was the first lens to use a Ring Type USM AF motor. All USM lenses at that time used an electronic focus ring. Later a clutch used under the focus ring was used to keep costs down.
-Demetrius
sueze
That is how I have it set ...
-Demetrius
May I ask.  Have you reviewed the user guide for the lens?  Are you familiar with how the focus distance switch and SA ring works with AF?
Demetrius, Canon may have updated that in f/w, but I don't know when or even if they did. I've been using it [RF 100mm f/2.8L macro] with my R's for at least three years and MFO has always been available. I just verified that MFO works with this lens on my R5, R6, and R6 II just in case my memory had lapsed, LOL!
Newton
Thank you! I have not seen that list before.
There are many reports of MFO override not working on the R5. But it works on the R6. Which seems odd that it works on one but not the other. Has this lens had a firmware update at all.
-Demetrius
What firmware version are your camera and lens on.
-Demetrius
Yes, I have the user guide on my computer and understand the focus distance switch. I do not use the SA ring.
