12-16-2013 01:28 AM
On image tests my 400mm L 5.6 is performing significantly less sharp than my new 100-400mm lense. The only think I can think of that would have damaged the 400 was condensaton in the body from temperature changes. Shots are all tribod and cable triggered. No filters on either lens. This is of course cropped way in. Any ideas? The 400 is about 9 months old. Can it be cleaned internally?
06-01-2015 11:36 AM
Guys none of this is of any importance to the issue here? The photos shown, here to us, have the problems. The OP claims one lens does fine and the other does not. The OP claims the same technique for both.
06-01-2015 01:06 PM
@ebiggs1 wrote:"Those are the words of someone who never lost half of an important shoot because he failed to check out a new lens that turned out to need +9 points of AFMA."
And you would be correct.
Why would a person go into "an important shoot" without knowing their equipment. That is DSLR 101, my friend.
I never took anything new or untried into any critical job, ever. Matter of fact everything was/is covered by backup equipment.
I don't dispute any of that. I had just received the lens and hadn't had time to test it. It's a mistake I haven't repeated.
But the point (for this context) is that when I saw the result, I had to learn about AFMA and apply it to that lens/camera combination forthwith. The alternative was to waste time sending it back and trying again. And the reason I was able to solve the problem quickly is that AFMA just isn't very complicated. You take a series of pictures and see which one looks the sharpest at the operative AF points. Not many things in photography are simpler than that. Advising an experienced photographer not to try it, on the premise that he probably couldn't get it right, makes little or no sense to me. Especially since it's impossible to screw it up in a way that can't be immediately undone.
06-01-2015 01:57 PM
Bob fome Boston said,
"Advising an experienced photographer not to try it, ..."
But I don't know this? Experienced? Taking it for granted are we? ![]()
"You take a series of pictures and see which one looks the sharpest at the operative AF points."
Now, Bob from Boston, we both know that is not how to do it. Don't we? It takes as Alan Myers suggested concentrated work done on a tripod. At a given target and range, carefully. Same, same each time.
It is a moot point because that isn't the OP's problem.
06-01-2015 03:35 PM
@ebiggs1 wrote:Guys none of this is of any importance to the issue here? The photos shown, here to us, have the problems. The OP claims one lens does fine and the other does not. The OP claims the same technique for both.
And that doesn't suggest to you that one of the lenses may need AFMA? If it doesn't, what would?
06-01-2015 04:00 PM
@ebiggs1 wrote:Bob fome Boston said,
The thread has been going for more than 17 months, so it's a bit hard to keep track of the players. But I don't see lack of experience as a significant problem with any of them.
Maybe so, if you think you have to be absolutely certain of your choice between 0 and +1 or between +8 and +9, etc. But I assure you that you don't need a printed target or a tripod to see the difference between 0 and +9. So yes, unless you're a compulsive pixel peeper, that's exactly how to do it. There have been some good papers written on how to do it intelligently, like photographing a scene with objects at various depths, so that you can see them come in and out of focus. But that's just an implementation detail.
I don't see how you know that, given the evidence presented.
06-01-2015 04:15 PM - edited 06-01-2015 04:20 PM
Bob from Boston.
"And that doesn't suggest to you that one of the lenses may need AFMA?"
Ah, no it doesn't. They look like camera shake to me as nothing is in focus. If it were close enough for MFA to help, something would be.
This looks like MFA is going to fix it?
By all means give it a go and let's see.
Why he can shoot one lens and not the other is puzzling but its not because of OOF. At least I guess it isn't? Which is what all this actually is.
06-26-2015 10:26 PM
Ok. got the lens back from canon. they said they had to adjust or calibrate some circuitry or something.
WORLDS improvement. the pictures it captures are absolutely fantastic. very pleased.
the same sign and a passing car like before (note the idiot in the car)
http://i.imgur.com/nByUpJi.jpg
http://i.imgur.com/oCW4MRe.jpg
such a big improvement. absolutely far superior to my old lenses. no doubt. even expanding on my 4k panel to 200 and 300% the images are stunning. Very pleased. I can't wait to shoot some rockets with this!
06-27-2015 09:04 AM
Fantastic! ![]()
07-14-2015 12:21 PM
I am having same problem and lens was less than a year old. Have sent it back to canon 2 times already. Shot a few photos the other day and it appears the focus is still soft. Will not be able to shot for a few more weeks, but when I do I will look at the photos and if not sharp I will send it back again. I have three canon cameras and probably 6 to 8 lens. All other lens are sharp on all three camers. but the 400 is not sharp on any of the 3 camerasI think it is a lemon. I do not understand as big as a company as canon is why they want send me a new replacement lens.
07-14-2015 12:28 PM
"... why they want send me a new replacement lens."
Whoa, there cowboy. Pull back on the reigns a bit. We first need to decide if it is the lens or the camera or you. If it is not the lens, a new one isn't going to help is it?
First off a sample of what you speak will be helpful. What camera and what conditions? What are the settings? Also if all is as you said, you need to send the camera and lens back together.
Have you tried this lens on other camers?
