09-09-2024 10:01 PM - edited 09-09-2024 10:03 PM
Hello!
I currently have a Canon EOS Rebel t7 and a few lenses I've purchased. My dad recently gave me his old camera, an EOS Rebel xs, and a bunch of lenses with it. Is there an adaptor that I can purchase to make the lenses that worked with his Rebel xs work with my Rebel t7? The lenses are a close fit, but not quite the same size.
I appreciate any and all help!
09-09-2024 10:47 PM
They use the exact same EF-S mount, the lenses should be interchangeable.
09-10-2024 08:59 AM
That is what I thought! However, the lenses are not acting as though they are interchangeable. I am unable to put the older lenses on the Rebel t7. I will keep investigating!
09-10-2024 10:10 AM
Do the lenses have a white square or a red dot alignment marker? Need to match the lens marking to the camera marking. If they are third party lenses they always mount the red dot on the camera, regardless of the alignment mark color on the lens.
09-10-2024 10:17 AM
Can you show them to us? Pics of the front of the lenses without caps and the bottoms without caps? That would be very helpful!
09-10-2024 10:18 AM
What is the exact wording on the lenses. Look on the very front of each lens and report back. You should see something like EF 50mm 1:1.2L.
09-24-2024 06:00 PM
One of the lenses that does not work for my Canon EOS Rebel T7 says "EF 28-135mm 1:3.5-5.6 IS"
09-24-2024 06:05 PM
Here are some photos of the 28-135mm lens. This lens does not seem to be compatible with my EOS Rebel t7.
09-24-2024 06:07 PM - edited 09-24-2024 06:16 PM
It is. Line up the red dots. Check that there is no damage to the lens mount.
09-24-2024 06:21 PM
I think I identified the issue -- I think there is slight damage to the lens mount. A little bit of the metal is slightly bent in one area. I was lining up the dots and it was not working. However, this would explain that!
