04-25-2014 11:07 AM
What filter wrench/spanner is good for use with rotating filters like circular polarizers? The cheap plastic "clamp ring" style are junk.
04-25-2014 02:36 PM
04-26-2014 12:32 PM
I use a technique of rolling the filter in a spiral type motion AS I attempt to free it from being stuck and it works fairly well for me.
I have a filter (which also happens to be a CPL) that likes to jam and I just try to careful not to fully thread it on... just enough turns to ensure it can't possibly fall off.
Sorry I can't offer advice on filter wrenches... everything I see these days is plastic.
04-28-2014 10:52 AM - last edited on 04-28-2014 11:43 AM by Crista
Desmond photographic Distributors makes metal filter wrenches: [MOD NOTE: Link Removed Per FORUM GUIDELINES]
I rarely have trouble with my CPL filters and when I do get a stubborn filter, my plastic wrenches always worked for me.
Review here: A Useful Aluminium Filter Wrench from Desmond
04-25-2014 12:51 PM
is this for removing stuck filter? I just use rubber band, it's easy, effective and free. 🙂
04-25-2014 01:44 PM
Yes, a stuck filter.
Rubber band works great for most "stationary" filters, but the rotating style (like a Tiffen circular polarizer) have only a narrow knurled area which is almost impossible to grip.
04-25-2014 02:36 PM
04-26-2014 12:32 PM
04-28-2014 11:20 AM
05-03-2014 03:13 PM
I am also interested in filter wrenches. The Desmond certainly looks better than the plastic variety. However, after searching the Desmond website and also eBay, there are two filter size groups for which no wrenches are available: 60-70mm & 87-100. Specifically, the wrench sizes are 52-58mm, 72mm-86mm, and 105mm-112mm. So, as long as your lens filters are within those ranges, you're good to go. In my case, I have two lenses that are 67mm and one that is 95mm.
