03-28-2014 01:04 PM
04-16-2014 03:45 PM
Hi evans1,
The WPS button is a button that may be on the access point or router that you are trying to connect your printer to; there is not a WPS button on the printer. Not all access points or routers have a WPS button, so if yours does not, you will not be able to setup the printer wirelessly using WPS, but can still connect the printer wirelessly using the cableless setup method.
To connect the printer wirelessly to your access point/router using a cableless setup, please follow the steps located at the link below:
PIXMA MX472 Wireless LAN connection of the printer using Cableless Setup
Hope this helps!
