01-15-2015 10:15 PM
I've just unpacked my MF8280Cw, pulled the strips from the cartridges, and added paper to the paper drawer. The red error light continues to flash - all this prior to attempting to connect the printer to a PC.
There doesn't appear to be a paper jam. I've removed the tray, re-inserted it and rebooted the printer several times.
I then plugged the printer to the laptop via USB cable but the Windows8 PC didn't recognize a printer.
Are there any other things to check for, or did I get a dud?
Thanks for your time.
Patrick
01-17-2015 12:37 AM
I took another attempt at getting the printer to work today. I powered it up, and stepped through the setup menu. After completing the menu options I now receive the following error message:
"Remove tabs/pieces of tape from the toner cartridge. Black(K)
I had, of course already removed the tape by pulling out the orange ring. Any thoughts?
Patrick
09-05-2015 11:59 PM
I am having the same problem with mine. I thought it was a defective toner cartridge so I replaced it at $143.00. Still the error message appears. I cannot get an answer to this problem.
