my Canon printer just started printing double images. How can I fix this?
dianacovell
I was away for a week and my printer was left on and now it prints double images.  I am self employed and need to use it!!!  HELP!!!!
AMAZING!!!  So easy but not somewhere you would look to fix it!!!
When I went to print something it didn't respond to CNTL P the first time so that must have been the message that something was wrong.
Thanks so much.
31 REPLIES 31
Italian4215
Enthusiast
What kind of printer is it?
MY EQUIPMENT:
EOS Rebel T4i
EF-S 18-55mm f/3.5-5.6 IS II
EF-S 55-250mm f/4-5.6 IS II
(2) B+W 5.8 010 UV - Haze 1x MRC (F - PRO Series filter)
HOYA 58mm HMC Multi-Coated ND8 Filter
It is MX 470 printer, copier, scanner
I did a quick search and came across this. Although it is for a 432, hopefully this imformation helps as canon printers are assembled relatively simular. 🙂
http://forums.usa.canon.com/t5/Printer-Multifunction-Support/I-had-a-paper-jam-on-my-MX432-and-since...
MY EQUIPMENT:
EOS Rebel T4i
Thanks so much.
MG3650
Frank3
I want to finalise my report, but cannot print an acceptable copy due to double imaging - HELP
My printer is MG5460, and has started to double image on printing
