07-10-2015 01:17 AM
I purchased this scanner about 18 months ago, but just started using it. I noticed that the photo scans are very slightly fuzzy. It is improved with the "unsharp mask", but this infuses noise into the image. It seems like a lens is slightly out of focus and needs "glasses". Anyone have any experience with this, and is it repairable?
07-10-2015 09:12 AM
Hi fisterace!
Welcome to the Canon Community Forums and thank you for your post!
So that the Community can help you better, we will need to know about any error messages you're seeing, and the Computer Operating System you're using (Windows XP/Vista/7/8 or Mac 10.x), as well as the way you connect to your scanner (USB or networked via WiFi or Ethernet). It's also helpful to know what software you're using to scan your documents and photographs.
If this is an urgent support need, please CLICK HERE to reach our friendly Technical Support Team by phone or email.
Thanks and have a great day!
07-17-2015 11:17 AM
No error messages
Connected by USB3 directly to computer
Windows 7 Home Premium
Using Canoscan interface through Adobe Photoshop Elements 11.
I also have an Epson 4990 photo scanner-and the same photo scans on that machine without distortion.
Thanks for your help
07-17-2015 12:13 PM
Hello.
Performing calibrations may help with this issue.
To perform calibrations, please follow these steps:
1. Click on Start, All Programs, Canon Utilities, My Image Garden and then My Image Garden to open the program.
2. Click Scan in the menu on the left hand side.
3. Click Driver at the top of the right hand side.
4. Click on the Advanced Mode tab in the upper right hand corner.
5. Click on the Preferences button at the bottom.
6. On the Scanner tab, choose ON next to Execute at every scan.
Perform 3 or 4 scans to calibrate the unit.
07-20-2015 02:14 PM
07-20-2015 09:53 PM
I went through the steps outlined,
After changing the settings on the scanner tab to ON for Calibration settings: Execute every time
I could detect no change in the quality of the scan
Or, the functioning of the ScanGear interface
Accessing it through either through the image garden or through the Adobe Photoshop Elements interfaces
If changing that setting to ON is supposed to add some obvious callibration steps to the scanning sequence, it doesn't
There is a slight improvement scanning at higher dpi, but not enough to really make it a usable image or justify the extreme file size created.
I am open to any other suggestions you might have but, as it is, it isoff enough to be unusable. This scanner got very high ratings at the time I purchased it. So, not many people must have this problem. But, alas, I waited a long time before I used it and I fear this unit may be an out-of-warranty lemon.
